4Runner tailgate... no power
Old May 25, 2007 | 06:43 AM
thegreydog's Avatar
It seems I have no power in the tailgate. There is no tag lights and the key doesn't work the window. Any suggestions?
Old May 25, 2007 | 07:21 AM
WFO's Avatar
WFO
Probably a ground. Check out where the wires go into the tailgate and find the ground, should be white/black. Mine is anyway.
Old May 25, 2007 | 08:08 AM
ewong's Avatar
The ground wire gets "corroded".
I had to take the harness apart and replace the ground wire.
When I cut the ground wire apart - it was totally "green" inside....
Use a HD (12guage?) fine wire (very flexy) wire I had around... very nice...
Old May 25, 2007 | 10:14 AM
EvLTwiN's Avatar
i am having the same problem but my window is stuck in the UP position......
Old May 25, 2007 | 01:51 PM
tombothetominator's Avatar
That makes for a fun time in the cargo area....
Old May 25, 2007 | 02:14 PM
funrunner91's Avatar
if you guys need any parts check my post
https://www.yotatech.com/forums/f180/2nd-gereration-rear-window-parts-ca-103743/
Old May 26, 2007 | 09:18 PM
weaselman's Avatar
i just wiggle the wires every so often or kick the tailagte and it starts to work, so idk...
Old May 27, 2007 | 05:16 AM
waskillywabbit's Avatar
Rear Window Troubleshooting:
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old May 27, 2007 | 05:26 PM
thegreydog's Avatar
It goes up and down fine with the inside switch, but the power at the tailgate seems dead.
Old Jul 1, 2007 | 04:04 PM
pattycakes77's Avatar
i just went to roll down my back window with the key and got nothing. switch inside didn't move the window either. tried the rear wiper and it worked once, then pushed the window switch and now the wiper doesn't work. i do have brake and tail lights, the license plate lights work, and no blown fuses or fusable links. i felt the window regulator and it was a little warm, even though it wasn't being used. i have a 3rd gen, '98 SR5 btw. one thing, when i pushed the "down" on the switch to the inside there was a clicking in the blue box (which i guess would house relays?) so i know it's getting power but no go.
i'm going to check the ground connections since this is happening to the rear wiper intermittantly and the window; i'm not convinced it's a relay or bad window regulator.
i'll post what i find should i fix the problem
patrick
Old Jul 1, 2007 | 04:48 PM
You're rear window might not work now cause it thinks the rear wiper is down and the rear wiper might not work cause the rear window doesn't work. It happens.
Old Jul 1, 2007 | 06:24 PM
Bigblock's Avatar
If I'm not mistaken you will not find power in the tailgate.It all works off the ground side of the power window relay.Which means you'll have to put the ground side of the test light on a 12 volt source,then check for ground.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
jon.r
Jul 11, 2015 03:34 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 8, 2015 12:05 AM
