Pcv Q
Old May 17, 2007 | 02:57 PM
FOCUSHERE's Avatar
Pcv Q
Ok so i changed my PCV i just bought a 87 ill get pics letter no mods yet but my 84 pu will be the donor for sas and dual trans hopefully
My question is when i remove the hose from my pcv my engine dies is this normal on my 92 (hahah such a toyo guy) with the 22re also it doesnt is something wrong? i thought the hose on the front of the Valve cover was vacumm to am i lost?
Old May 17, 2007 | 04:32 PM
MudHippy's Avatar
If it's a 3VZE, that's normal. Don't Know why not on the 22RE. Any tubes coming out of the valve cover will be vacuum tubes of some sort. If you plug the holes when you remove the hose, it should run.
Old May 17, 2007 | 04:57 PM
MMA_Alex's Avatar
thats correct if you take it off you create a vacuum leak which will kill it if large enough.
urabus
Nov 10, 2015 07:38 PM
shredder4286
Oct 1, 2015 01:09 PM
puddlepirate
Sep 29, 2015 08:02 PM
kawazx636
Sep 29, 2015 08:22 AM
voiddweller
Sep 28, 2015 11:21 PM
