Throttle response,carb adjustment?
Old May 18, 2007 | 04:48 PM
fcovert2's Avatar
From the dead stop position and when going from gear to gear with an automatic transmission,my truck is bogging out.When I step on the gas the truck hiccups and hesitates before accelerating.Once it starts to go it will be fine,sorta.Its as if there is a sweet spot in the throttle if I tap it when accelerating.Theres a 4 barrel Holley carb that I dont really know how to fine tune to the 22r.Im also running a Mallory dual point distributor.Just put this engine in couple weeks ago and am running the same carb ignition setup.Need help.Rebuild carb?float adjustment?Air fuel mixture?Power valve?Go back to stock 2 barrel?
Blamalam
Mar 12, 2022 07:34 AM
crammit442
7
Nov 29, 2017 12:30 PM
mtc1105
Aug 4, 2015 08:06 PM
rbh261
Jul 13, 2015 12:04 PM
smiley52
Jul 11, 2015 05:16 AM
