Looking at doing 4.88's
Old May 15, 2007 | 10:59 AM
Wheelingnoob's Avatar
I have a 93 runner with a 3slow and 5spd. It has 4.56's now but I am looking at getting gears to go with my 33" tires. Can I take a 3rd member out of a Auto with 4.88's for the rear and the front diff from the same truck (v6 Auto)?
Will this work or would I be better off just getting the gears new?
Thx
Old May 15, 2007 | 11:10 AM
RustBucket's Avatar
Yep! Just replace the whole third members.
4.88's a good choice for 5-spd 33's
Old May 15, 2007 | 11:32 AM
8yota9's Avatar
when you swap gears do you have to mach the front to the back?
Old May 15, 2007 | 11:40 AM
Thanks guys that will make it easy!
Yes you do need ot match the gearing front and rear. If you do not the one diff will be spinning faster than the other when its in 4wd = not good.
Old May 15, 2007 | 04:05 PM
gonzo's Avatar
I just did the same thing to mine. Easy swap. Before I put the front in I removed the stock studs and put in regular hardened bolts so to make the cv axle easier to change out.
Old May 15, 2007 | 09:24 PM
4WDarren's Avatar
How easy do those studs come out? I've got a front diff. waiting to go in, and I've heard about that trick...now is the time to di it I guess. Did you have to pull the stub axles out?
Old May 15, 2007 | 09:39 PM
I just did my studs tonight and it was easy just make the nut lose and tap it with a hammer (with the nut on) then when its lose pull it out. Took me about 25min in the truck.
Jeremy
Old May 16, 2007 | 04:45 AM
gonzo's Avatar
Jeremy
X2
Real easy to do
Old May 16, 2007 | 04:51 AM
Hayes's Avatar
is 4.56-4.88 really enough change to make it worth the money and work?
Old May 16, 2007 | 07:24 AM
gonzo's Avatar
I can't see any difference in rpm, maybe 25 rpm diff. But I do see better take off from a stop and it pulls hills better. I can run hills in 5th now where before on the same hill I had to drop to 4th. I haven't been thru a full tank yet but looks like it will be a little better gas milage too.
Old May 16, 2007 | 07:41 AM
ekspc's Avatar
can you do the gear change and keep the same tire size? will it help off the line?
Old May 21, 2007 | 11:20 AM
ekspc's Avatar
bump*
Old May 21, 2007 | 02:41 PM
tc's Avatar
tc
DEFINITELY.
To the OP - I would think twice about using the stock 4.88 diffs. They have an offset pinion and are NOT regearable. If you ever went to a different tire size, or god forbid, had a problem, you will be stuck with buying thirdmembers again.
There is quite a market out there for your 4.56's, it helps greatly to defray the cost of regearing.
Old Oct 9, 2007 | 10:28 AM
Kno3del's Avatar
for the front (IFS) would i buy the same gear as i would for the rear? as in by two of the same thing? or would i have to get a different type of gear? i know the ratio has to stay the same.
Old Oct 9, 2007 | 10:33 AM
tc's Avatar
tc
The front is 7.5" "Toyota IFS", the rear is Toyota 8".
BE SURE THEY DO NOT SEND YOU TACOMA GEARS.
http://home.4x4wire.com/erik/diffs/
Old Oct 9, 2007 | 11:13 AM
Jay351's Avatar
Hey Jeremy, where did you find the 4.88's ?? I have been lookin for months!
Old Oct 9, 2007 | 12:28 PM
Kno3del's Avatar
if it says that the gear "also fits Tacoma / 4runner w/ factory trd e-locker -check spline count" will it work?
Old Oct 9, 2007 | 02:13 PM
tc's Avatar
tc
Yep - that's the one you need for the rear.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
Badlander
Oct 10, 2015 08:05 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
AkitaDog
Sep 3, 2015 09:01 PM
