transmission and transfer case question
Old May 22, 2007 | 09:22 PM
89silverpu's Avatar
So this probably has been covered on here but I can't seem to find it buy my questions are, what is the best transmission fluid for a manual transmission on an 89 pickup with a 22re and, the same question but for the transfer case? And how much goes into each? I really need to change them and want to do it this wkend. Thanks in advance.
Old May 22, 2007 | 09:26 PM
Elton's Avatar
see my thread https://www.yotatech.com/forums/f2/finally-changed-gear-oil-116384/ your tranny and x-fer should be pretty close i put 2qts for red line mt-90 and a little 75w-90 in the tranny to be safe and a little over a qt in the x-fer
Old May 23, 2007 | 08:35 AM
weakyota91's Avatar
a synthetic gear oil 80w-95 is best such as mobil one. Its pretty pricy about 11.99 a quart and u need 4.4 for tranny and transfer case together withch is close to $60 for just fluid but i change myne every 40000 miles and still comes out thick and clean. I have never used redline but heard nothing but good stuff about it. Tranny holds 3.2 QTS Transfer case holds 1.2 QTS
Old May 23, 2007 | 08:38 AM
dlbrunner's Avatar
Keep in mind there is a slight difference in fluid capacity between the V6 tranny and xfer vs. the 22re.
It is covered in the owners manual
Old May 23, 2007 | 09:34 AM
GV27's Avatar
My thoughts on the subject:
Only use MT-90 in the tranny. It's designed to have a bit of "bite" to it to allow the syncros to work better. Transfer case has no syncros so basically you want the slickest, highest film strength stuff you can. I use Redline Shockproof light weight (which is really medium in their lineup - superlight, light and heavy) but the M1 stuff mentioned above, Amsoil S2000 or Redline 75w-90 are all very, very good. I wouldn't use the M1 or Amsoil in the tranny - just too slick. Your syncros will hate you, though I guess that depends a lot on the condition of the syncros.
If you're having trouble sourcing these, a lot of sportbike shops carry these things.
Old May 23, 2007 | 01:34 PM
89silverpu's Avatar
So any MT-90 fluid will work in the tranny and can I just use the same 80w90 oil I used in my differentials in my transfer case?
Old May 23, 2007 | 08:10 PM
Elton's Avatar
yes mt-90 for the tranny and the 80w90 for the x-fer should be fine
Tykiller1994
Aug 10, 2015 07:49 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
crashburnoveride
Jul 10, 2015 06:39 AM
