better way to seal front end?
Old May 23, 2010 | 05:48 PM
tpaine14's Avatar
if this has been asked before i apologize but its been about a month or two since i stripped my front end to grease and repack bearings and hubs and spindle bushings etc. today i was going through my brakes and was going to change my rotors but when i got back into my hub my new timkin outer wheel bearings were spent. they had been well packed with synthetic bearing grease and my hub was full of mud and water. i changed the wheel seals obviously last time but they also i would assume failed. yes i drive my truck off road but i dont daily and am not in mud all that much anymore. i thought i was good about greacing things regularly is anyone else having this issue? is there a way to seal it better? am i doing something wrong? like not greasing them enough? i do it generally with the start of each season. idk this just sucks any help would be nice. not only am i doing front and rear brakes but now rotors wheel seals and bearings. not to mention a popping lower ball joint...like always any help is appreciated. also if it matters my truck is a 1993 22re lock in hubs.
Old May 23, 2010 | 05:58 PM
waskillywabbit's Avatar
New gaskets, seals and o-rings (as the little one in the end of the hub dial).
Old May 23, 2010 | 06:00 PM
tpaine14's Avatar
ok and which gasket would you be talking about? sorry i dont have the pieces in front of me. thanks for the input too.
Old May 23, 2010 | 06:03 PM
Manual hub dial o-ring
Manual hub dial star gasket
Manual hub round gasket
Unless its coming in the back side of your wheel hub, then you need those gaskets and seals.
Old May 23, 2010 | 06:04 PM
tpaine14's Avatar
thank ya much man.
Old May 24, 2010 | 07:23 PM
Matt16's Avatar
I used RTV for all the hub gaskets (save the o-ring), it worked well.
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
