Need Help- Hub Problem?
Old Jun 9, 2010 | 05:03 PM
clonman123's Avatar
I have a Hilux 93 sfa with manuals hubs. When I try to use the 4wd it binds(clicking noise) up as I drive so much that I don't dare try anymore. When I try to shift out to 2wd it is stuck in 4wd. If I then lift the front of the ground one of the tyres spins backward briefly and then Im able to shift back to 2wd. Ive tried the reversing trick and it doesnt help. If I put the shifter in 4wd without the hubs locked it drives fine-no noises or binding. If I drive it with the shifter in 2wd but with the hubs locked I get a rapid clicking noise as I drive. Any ideas what this is? Am I right in assuming I can remove the bolts on the hub to inspect inside? Any ideas what I should be looking for?
Old Jun 9, 2010 | 05:11 PM
iselloil's Avatar
It sounds like the bushing in the spindles are bone dry.There is a link on makeing a tool to lube the inside of the spindle.
glowz825
Jan 25, 2022 09:28 AM
oldirtydirt
Feb 23, 2020 09:30 AM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
