'90 4runner starter solenoid switch
Old May 24, 2010 | 10:59 PM
4runner316's Avatar
I seem to have an issue between my ignition and my starter solenoid. My starter solenoid isnt getting any power from the ignition. If i try to start her up, I get nothing. No starter click. I found the starter solenoid line under the hood and if I run a wire from the battery to the line then she will start right up. I know there is the starter relay in the fuse box under the hood - is there a fuse somewhere else? Does anyone had a diagram of the starter solenoid line?
Thank you!
Old May 25, 2010 | 09:15 PM
4runner316's Avatar
I understand this might also be a bad ignition switch. How difficult is it to replace that?
Old May 26, 2010 | 06:11 AM
bikedave99's Avatar
Hey 4Runner316, welcome to YT! It would help if you told us the year of you runner. Also, if you haven't yet, peruse 4Crawlers' pages on the starter: http://www.4crawler.com/4x4/CheapTricks/Starter.shtml Go almost all the way to the bottom and he describes what you are talking about. I am currently in the same boat as you but it sounds like my truck is a bit newer then your runner as I have a relay under the hood. It is screwed to passenger fender near the big vaned resistor and the fuse box. Has a goldish metal cap crimped on it. If you have a relay, see if it is clicking. Also, ignition switch shouldn't be to hard to replace, I pulled all the plastic off my steering column the other week to clean under there and fix my broken horn contacts and it was right there.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Johntom240
7
Jul 13, 2015 12:18 AM
crashburnoveride
Jul 10, 2015 06:39 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
