easy to replace front passenger window on a 93 pickup
Old May 30, 2010 | 01:06 PM
gary96360's Avatar
my window got smashed while i was at a party and the box was kicked in, i was wondering is it pretty easy to change out the window? i see that theres two 10 mm bolts holding the window to the metal piece.
Old May 30, 2010 | 02:50 PM
mrddk92's Avatar
yeah its pretty easy. 2 bolts and thats it. might require a little fenagling to het in.
Old May 30, 2010 | 07:02 PM
gary96360's Avatar
got to take off the trim and stuff?
Old May 30, 2010 | 07:25 PM
mrddk92's Avatar
well the door panel has to come off. thats not too hard
Old May 30, 2010 | 07:32 PM
gary96360's Avatar
ya i got that stuff off the night it broke i mean the trim around the window
Old May 30, 2010 | 07:50 PM
Jay351's Avatar
Nope, just remove the door panel (with window crank, door handle etc)
Then rotate the glass 90 degrees and lower it in through the inside of the door. Then rotate it forward and drop it down.
Worked like a charm for me
Old Jun 2, 2010 | 10:37 PM
gary96360's Avatar
ya it took me two mins to put the window in with the panel off. thanks guys
Old Jun 3, 2010 | 12:42 AM
prorunner's Avatar
I had troubles doing it with the trim on, I had to pull it off and out of the door, it made it way easier getting the window in, but the trim is a pita to shove back down the into the door in the window guides.
Outsane
Jun 24, 2015 05:52 PM
