dangers of running GL5 in the tranny?
I replaced my tranny fluid about 2500 miles ago with GL5 gear oil. I guess I didn't do my homework prior to switching the fluids, since I'm just barely learning now that GL5 can be problematic to the tranny. So I'll be switching over to either Redline MT-90 or Royal Purple Sychromax soon.
My question is: Have I done significant damage to the tranny? Is there anything, besides switching over to a GL4 oil, that I should do now?
ask your self this.
if the GL or API rating is to determine the grade of the product then why would running a better/higher grade hurt your transmission?
also, why would running synthetic fluide's have any better results then what was recomended for the vehical.
I am thinking of switching to synthetics in the tranny simply because the only GL4 oils I have found happen to be synthetic. We don't need to turn this into a dino vs synthetic debate, since we have plenty of those
First off, I can't even find GL4 Gear oil anymore. It's all GL5 and I run it in mine. And have for quite a few years.
And I can't comment on if its a rating or a rating of additives.. No idea. Just know my tranny works fine and has 207K HARD miles on it and shifts perfectly. =/
I do know that when the Haynes manual I have came out, GL5 wasn't around.
If I had to guess, I'd say it's some kind of quality rating, not a variant of some kind of gear oil. Like a API rating.
So I got curious and did some searching around... yea its not a quality rating, its a rating of the additives in the oil.
But, unless you can find GL-4 Gear oil here, you're stuck special ordering from somewhere (dunno where? heh).. but like I said I've been using GL5 for years.. I'm sorry Im not special ordering oil for my 22 yr old pile. Tranny has been fine.
I found this comment on a Unimog forum,
"I talked to a tech at Valvoline about their dual rated GL-4/ GL-5 gear oil. He said there are different additives that can be used to make the oil Extreme Pressure rated ( GL-5) . He said the additives that Valvoline uses in their GL-4/GL-5 will not harm yellow metals ."
and from my searching I found that yellow metals are brass, bronze, copper.... Which bushings are typically made of (like in our spindles).. but I dont know whats all inside our transmissions, thats the only part of my truck I've never cracked open.
I used Mobil1 Synthetic in my transmission and Valvoline dino oil in my difs
GL4 is available from a variety of sources.
And, most dealerships have been using 75w90 GL5/6 since the trucks were brand new. Don't worry, your truck probably had GL5 in it for 20 years before you got it.
That said, I like the shifting performance of Redline MT90 the best of all the oils I've used, which are a LOT of them.
GL5 is NOT necessarily backwards compatible with GL4 although some brands MIGHT be.
But why can I no longer find GL4 in any of the parts stores in my area, and just in the past few years they've all switched over to GL5? And when I could get GL4, I couldn't find GL5?
No, GL-5 is not new. The driver's manual for the 94 pickup says to use either GL-4 or GL-5 in the manual transmission. I think there's a good chance that the transmissions had GL-5 put in them at the factory. If any transmission oil has been added or replaced over the years, chances are it's GL-5.
the1998sr5
15
Jul 14, 2020 08:35 PM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
Jnkml
Jul 6, 2015 01:20 PM
