Timing Chain
Old Feb 5, 2009 | 06:33 PM
86yota2wd's Avatar
Timing Chain
I was wondering when you are supposed to replace the timing chain I know belts are apporx 75000 to 100000? When should i replace the timing chain. I have a 22R im pretty sure it doesn't make a difference but i thought id throw it in there.
Old Feb 5, 2009 | 06:55 PM
fireman1559's Avatar
60000 is what i would do any longer than that in my opion is to long but when it comes to my truck i play it safe yea i do a water pump and timing belt every 60000 on my truck but thats me
Old Feb 5, 2009 | 10:50 PM
drew303's Avatar
Belts 60-75k, chains 100k.
It's purely precautionary. Both can last much much longer but, after a certain mileage you just don't know if it'll break.
With the 22R/Es.. the guides like to wear through... so the chain could either be fine (ok guides) or have broken through a guide which cuts their life down... pretty obvious.. metal on metal grinding even with oil is never good.
When a chain/belt breaks, the motor usually doesnt survive. Bent valves, punctured pistons etc..
Old Feb 5, 2009 | 10:55 PM
toyota4x4907's Avatar
I've read/heard 130K-160K. No more than 160K unless you're a risk taker
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
razorman8669
Jul 12, 2015 12:13 PM
