gear oil
Old Feb 4, 2009 | 09:16 PM
eich75's Avatar
gear oil
i replaced my clutch in my 88 yota today and changed the gear lube also, i put 80w90 in it just to get it out of the shop... now it takes tremendous force to down shift, would that be because of the gear oil or did i screw somethin up? i no it takes 75w90 but all i had with me is 80w90... i did research on this but nothing gave me a clear answer
Old Feb 4, 2009 | 09:25 PM
Matt16's Avatar
Trannies can be quite picky about what oil they use. Sounds like you used an oil which is too slippery for use in a manual transmission and the syncros aren't working properly. I suggest you go with Redline MT90. Its about $40 in oil to fill the tranny, but it works beautifully, don't know about any other types of fluid.
Old Feb 4, 2009 | 09:42 PM
eich75's Avatar
thanks for the info... i was scared ha ha
Old Feb 4, 2009 | 11:08 PM
Elton's Avatar
i got redline mt90 in mine it shifts real nice
Old Feb 5, 2009 | 07:01 AM
Whiplash Willy's Avatar
Make sure you are using GL-4 in your tranny, GL-5 can damage the Syncros. I use AMSOIL Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 API GL-4 (MTG), and it has made a huge improvement in shifting smoothness.
Old Feb 5, 2009 | 07:32 AM
mikepr55's Avatar
where can i find those kinds of oil i am looking at servicenig my 5 speed soon and would like to use something like that either one but i guess gl-4 is what i am supose to use? 1984 straight axle. 4cyl
Old Feb 5, 2009 | 09:05 AM
Matt16's Avatar
Yes, should work for an '84. Those are W?? trannies right?
Old Feb 5, 2009 | 09:09 AM
874runnersr5's Avatar
hmm where can you buy this redline stuff?
Old Feb 5, 2009 | 09:49 AM
99SR5's Avatar
yes i would also like to know where to get the red line stuff
Old Feb 5, 2009 | 10:34 AM
Elton's Avatar
i ordered red line from summit racing
Old Feb 5, 2009 | 11:53 AM
Matt16's Avatar
I bought mine from Lordco- a local BC auto parts store.
Old Feb 5, 2009 | 03:12 PM
eich75's Avatar
would it work in my transfer case?
Old Feb 6, 2009 | 09:54 PM
Keith B.'s Avatar
AND...it'll probably last 2x as long as non-synth gear oil. OK in transfer also, but do not use in differentials...GL-5 for the diffs.
smthwsn357
May 1, 2024 07:28 AM
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
mengquis
Jul 13, 2015 10:39 AM
Jnkml
Jul 6, 2015 01:20 PM
