Starting Problems
Old Feb 8, 2009 | 04:48 PM
RevMBW's Avatar
Starting Problems
Hey Gang,
Brand new here. Just purchased a 1991 4Runner 2wd v6 with 151,000 miles for $1000. Great price for super clean runner. It has a new starter, alternator, plugs, wires, distributor, coil and ignitor and it will still not start now that all that is replaced...Any suggestions? I tried pulling the alternator fuse, looked like it was fried and it just disintegrated as I tried to pull it. Any suggestions in getting it out as well. Any help would be great. Thanks!!
Old Feb 8, 2009 | 05:27 PM
INFINITY's Avatar
details??? do you hear a click? turn over? what?
Old Feb 8, 2009 | 05:29 PM
RevMBW's Avatar
It turns over just fine. Had the battery charged and checked...all is good there too. Seems to be no fire...
Old Feb 8, 2009 | 10:08 PM
desconhecido's Avatar
Was it running when you bought it? Does the rotor go round when you crank it?
Old Feb 9, 2009 | 06:15 AM
Bobzombie's Avatar
The alt fuse has nothing to do with the vehicle starting it would only affect the charging of the battery.
First thing to do is to check
Spark- pull a wire off the plug pull plug put back in to wire and sit plug against block(grounded surface) and turn key You should see a spark. carefull how you hold it or it will light you up :smilie:
Fuel- easiest way is to turn key on a few times and crack the cold start injector line loose. You should see fuel squirt out for a second. fuel pumps are a common failure.
I delt with a no start and had a hell of a time until I finally found the problem.
Let us know what you find on these above items
Old Feb 9, 2009 | 09:12 AM
RevMBW's Avatar
Thanks guys...I will check all the above the next day or two and let you know how it goes...thanks!!!
Old Feb 11, 2009 | 07:04 PM
RevMBW's Avatar
Fuel Pump is fine and there is no spark. There is power to the coil and igniter but not to the distributer...any thoughts??? Thanks!!
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
