plugging a tire
Old Feb 12, 2009 | 05:45 PM
Matt16's Avatar
plugging a tire
Tire encountered a framing screw (1/8") which poked right into through the tread between two lugs. I repaired it with a tire plug kit. The kit says its only good for 100km, are they just covering their butts or will the plug be alright for a long time to come?
The tire is an 31" LT tire C-load rating. I trimmed the plug flush and used lots of the little package of glue provided.
Old Feb 12, 2009 | 05:53 PM
bigt's Avatar
usually they will be ok BUT I NEVER USE THE KIT UNLESS ON THE TRAIL.. id take my expensive tires to get fixed right by the people that put them on...they glue them form the inside and clean and re mount...
but i do have a few plugs in my mudders and they work good
Old Feb 12, 2009 | 05:54 PM
tc's Avatar
tc
The little "rope" type plugs?
I've had them in some tires a LONG time.
Old Feb 12, 2009 | 06:02 PM
bigt's Avatar
yeah the sticky rope ones that comes with the reamer fist grip with the hook jobby on the end!!
crappy tire isle 3 7.99 kid
on a side note i seen a older carvan drive by my work yesterday and the tire on the drivers side front BLEW AND MEAN BLEW!!!!!!
it was crazy.. BANNNNG to riding on rim .3 seconds
Old Feb 12, 2009 | 06:08 PM
iamsuperbleeder's Avatar
I've used those "stick-rope" style ones many times and have never had any issue
I've put them on family member's cars and trucks with no worries, and they's never had any issues
so long as you get the little deburrer and clean the opening out right and set it in right, I don't see why you would have any problems
I don't know if I would call it a PERMANENT fix, but I've had them last me thousands apon thousands of miles. I had one in the left rear of my 2000 Mustang and I routinly took it well over 100mph, and she never let loose on that note, they also were not 31's, so the cintrifical force on the plug may not be as great on a smaller tire as it is on a larger off-road tire... but still...
Old Feb 12, 2009 | 06:09 PM
bigt's Avatar
your lucky she never let loose!!!!! thats a roll over waiting to happen
Old Feb 12, 2009 | 06:11 PM
especially considering that on the best back-roads back where I lived when I had the car, I took the corners well over 75mph I miss that car sometimes...
Old Feb 12, 2009 | 06:38 PM
cormel's Avatar
you'll be ok with a plug, I have done it at least a thousand times and never had any issues.
Old Feb 12, 2009 | 06:40 PM
you overexagerater...
a thousand times?
comon now...
I find that hard to believe...
Old Feb 12, 2009 | 06:41 PM
Elton's Avatar
i used those little rope ones and didn't get cheap with the glue its been holding air for the last 4months
Old Feb 12, 2009 | 06:49 PM
Matt16's Avatar
The only way I think that could happen is if the plug blew out, let most of the air out without noticing, the side-wall heated up and blew out. I think I'd notice the low tire through changes in handling before that happened. The side wall has to heat up to fail usually from what I've heard.
EDIT: didn't realize you were talking about the Mustang.
Old Feb 12, 2009 | 08:03 PM
Jay351's Avatar
x2! I had one of those in my old tires for 2 years...... Held till I sold em.
Old Feb 12, 2009 | 09:04 PM
rangerruck's Avatar
the plug is good, especially if hole is all the way down, between treads. of course the best is an interior patch, but the plug should be just fine.
Old Feb 12, 2009 | 09:26 PM
Matt16's Avatar
The outside of the hole is 3/16" away from the pavement.
Old Feb 12, 2009 | 09:40 PM
SpecialScottie's Avatar
Once I even had to plug a sidewall with those rope things and it held for a long time
Old Feb 13, 2009 | 03:35 AM
cormel's Avatar
ok, not a thousand times maybe 30
But I can't remember ever having a problem with a plug I put in. As long as as it is in the treads and not on the side wall, you should be fine.
Old Feb 13, 2009 | 04:20 AM
ozziesironmanoffroad's Avatar
careful, if you do it wrong, it voids the tires warranty. the only time id reccomend using a plug is the trail, then get it to a tire repair shop. plugs suck.
Old Feb 13, 2009 | 04:30 AM
cormel's Avatar
yes I would have to agree, if you still have warranty on the tire and can get int fixed for free, get the tire company to fix it by putting a patch in the inside. All I am saying is that if you need to fix it and don't have warranty the plug method has worked just fine for me in the past.
Old Feb 13, 2009 | 05:23 AM
RobD's Avatar
I've done dozens of tires and run them for thousands of kms, without a single problem.
I have been told that Goodyear won't warranty a tire that's had them done, but I cannot verify that statement.
Old Feb 13, 2009 | 05:42 AM
Corey's Avatar
Co-Founder/Administrator
I have one of those rope type kits in the rig for an emergency.
Someday I would like to practice on a used tire.
Maybe on a trail seminar some day.
Here is a video from YouTube.
Even though I do not know much German, I can get enough from the video on how to use it.
[YOUTUBE]BrpNIqMstpw[/YOUTUBE]
Here is one for a motorcyle.
Takes him almost longer to get the screw out than it does to patch the tire.
[YOUTUBE]p9P7qmbMyjc[/YOUTUBE]
Here is a good one from Africa.
Best video of them all for our use.
[YOUTUBE]H186BE4Hu_w[/YOUTUBE]
