What is this?
Old Feb 19, 2015 | 11:05 AM
NextR's Avatar
What is this?
What is the name of this part?
[YOUTUBE]
[/YOUTUBE]
Old Feb 19, 2015 | 02:39 PM
LITLRED's Avatar
The pipe you are pointing to is a coolant fitting. Above where you art pointing is where your EGR is blocked off. This could be causing your surging idle by creating a vacuum leak with that filter on top of your valve cover. I would reconnect your egr hose and see if that helps your idle.
As for the coolant hose, try heating it with a heat gun and twisting gently.
They tend to stick if not removed in years.
A couple years ago I bought an entire 22re efi intake off craigs list and its really come in handy for spare parts.
Old Feb 19, 2015 | 02:58 PM
NextR's Avatar
She had the surge before that, but you are correct. The caps are all dry rotted and theirs a big ass vacuum leak.
