dazed and confused
Old Jan 31, 2015 | 05:59 PM
Rockett76's Avatar
dazed and confused
I changed my motor mount and now my 95 4runner won't stay running. At first it wouldn't start but if I keep the rpms at 2000 or above it runs but chugs and dies if I take my foot off the gas. Was running good before this. Please help!!!!
Old Jan 31, 2015 | 06:04 PM
mchapter's Avatar
was the mount on the side that has the air filter and intake? make sure all those connections are tight.
generally speaking, did you have to disconnect anything to replace the mount? that would be the area to check first. think, distributor, plug wires, air filter, etc.
Old Feb 1, 2015 | 12:41 AM
Rockett76's Avatar
It was on airfilter side and all those are good
Old Feb 1, 2015 | 02:18 AM
wyoming9's Avatar
Red face
Is the ground for the ECU loose if you changed the right side mount
Old Feb 1, 2015 | 07:19 AM
Gevo's Avatar
sounds like a vacuum lean, particularly in the crankcase/valve cover area.
After filling oil once i left the oil cap off and the symptoms were exactly what you just described. I freaked out for a brief 1.5 seconds and then saw the oil cap. lol
Obmi
Oct 30, 2015 04:27 PM
Boomer8404
Sep 24, 2015 01:12 PM
vikinghug
Sep 23, 2015 12:32 PM
Boomer8404
Sep 20, 2015 06:15 PM
PBRaddict#1
Sep 14, 2015 04:18 PM
