HELP injecters wont fire on my 86
Old Jan 27, 2015 | 06:27 PM
onetonyota's Avatar
Exclamation HELP injecters wont fire on my 86
it started a month ago I was wheelin in Johnson valley I came down on a rock the negative terminal came off the battery and went back on and the truck died. I later found out no injectors were firing except the cold start. it would run on starting fluid or until it died from cold start fuel. ive checked all the basics. my friend has an 85 22re we tried swapping computers and mine didn't start his truck. im gonna replace the efi relay next. I replaced the circuit opening relay and tried swapping the injecter relay still no starting. I got the harness open and im not finding much. im gonna replace the wires from the comp to the igniter assembly next. any ideas bros this really sucks
Old Jan 27, 2015 | 07:25 PM
Terrys87's Avatar
To see if your computer is sending the pulse https://www.yotatech.com/forums/f116...t-22re-270857/
If it is sending the pulse, I would remove the crimps in your wiring harness.
Old Jan 29, 2015 | 02:36 PM
RJR's Avatar
RJR
Is this what you meant to say? Because if it is, it points to your computer being bad. Not common, but it sounds like you had a pretty good electrical "event", which could have taken it out.
ladybugRC
458
Aug 21, 2020 10:41 AM
Alexdosdall
Dec 10, 2017 05:48 PM
wberry85
May 17, 2016 05:45 PM
smilen724
13
Nov 8, 2015 04:11 PM
bradahman
Oct 1, 2015 09:24 AM
