Chunks of rubber in PS fluid
Old Feb 3, 2015 | 12:51 PM
Tin Soldier's Avatar
Little black pieces of rubber are in the bottom of the cup that I drained my PS fluid into. The fluid was frothy, tired to bleed air, tightened all the fittings and tried again. Can't seem to get the frothiness down. I'm assuming that the PS internals are shot and I need to rebuild or get a new one. Although I'm wondering, does the inside of a PS pump actually have rubber o-rings and so forth? I assume so, but I'm not super knowledgeable on the internals of hydraulic pumps.
Thanks
Old Feb 3, 2015 | 05:06 PM
I opened up the PS pump and didn't find any rubber or worn out parts. The steel fins looked good and the o-ring was good. I put it back together and then cleaned the reservoir. Not much crap came out of the reservoir, but after I put it all back together the forthiness went away and the PS pump works good. Chunks of rubber might have actually been part of the hose where it got scuffed when putting the tubing back on the pump previously.
Old Feb 3, 2015 | 06:32 PM
RJR's Avatar
RJR
Was it actually rubber, or was it possibly bits of RTV gasket sealer from an overzealous PO trying to repair a leak? Too much of that stuff will tend to break off and float around in the system. Feels rubbery.
Old Feb 3, 2015 | 07:03 PM
I'm the PO. Owned since I bought it new. It was probably the tubing, I suspect.
ladybugRC
458
Aug 21, 2020 10:41 AM
zanzabar0
Oct 11, 2015 02:56 AM
bradahman
Oct 1, 2015 09:24 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
voiddweller
Sep 28, 2015 11:21 PM
