86 horn circuit, can't find the relay?
Old Jan 15, 2022 | 02:03 PM
Fm900's Avatar
Tried to search the threads, no luck...there has to be a relay somewhere. Does anyone have a wiring diagram? I checked the block up in the front left of the engine there's a 10 amp fuse that runs the hazard and Horn. I checked the block drivers under dash, no relay. There's a block behind the kick panel bottom left drives.
I had to fix the thing behind the steering wheel... After all this mess I'm just going to replace the horn, mine is original and kind of anemic. Hobo freight has a nice set for 10 bucks comes with a relay. I don't want to wire the relay in if I can find mine but I can't find it.
Thanks!
Old Jan 15, 2022 | 02:43 PM
wallytoo's Avatar
Originally Posted by Fm900
Tried to search the threads, no luck...there has to be a relay somewhere. I don't want to wire the relay in if I can find mine but I can't find it.
you can't find it, because there isn't one. toyota did not use one in the '86 4runner.
Old Jan 15, 2022 | 04:23 PM
Fm900's Avatar
2x4
I have a regular 2x4.... tks
Old Jan 15, 2022 | 04:39 PM
RAD4Runner's Avatar
Like Wally says, there is no relay on the 1986 to 1988. I don't know when they added the relay.
Here's how to troubleshoot horn:
https://www.yotatech.com/forums/f116.../#post52381275
Here's how to add a relay:
https://www.yotatech.com/forums/f116.../#post52401824
Old Jan 15, 2022 | 06:14 PM
wallytoo's Avatar
did you find the relay?
grue
Nov 2, 2021 10:41 PM
skidder
Jul 13, 2020 09:50 AM
Bryan4x4
Feb 10, 2017 09:31 AM
Kiroshu
Apr 16, 2016 03:07 PM
eightsevenzero
Apr 14, 2015 10:56 AM
