LSPV bleeder screw broken
Old Feb 16, 2022 | 12:33 PM
jaskotmb's Avatar
I have a 1987 4Runner. While trying to bleed my brakes after a rear axle gear swap, I noticed the LSPV bleeder screw is broken off, so I can't bleed the LSPV. This is one of those with a solid hex head bolt and a separate bleeder nipple. Does anyone know if I can get this bleeder screw anywhere without buying a new LSPV? If I can, I'd drill out the broken one and replace it, but the dealership says they don't have a part number for just the screw. I assume it is (some thread?) metric hex screw with a conical tip like the other bleeder screws, but instead of having a hollow passageway thru it, it just opens a port to the bleeder nipple on the side.
If I can't find one, what do you think the most successful way to bleed my brakes without touching the LSPV is? Can I even fully bleed the system without being able to bleed the LSPV? I basically dumped all the fluid out of the rear when disconnecting the lines. Just kills me to pay $218 to the dealership for a new valve when all I need is the screw. Most trucks have the standard hollow bleeder screw too, so it's hard to find in the junkyard... Guess I could spend $120 for one on eBay, but still...
Old Feb 16, 2022 | 06:33 PM
Melrose 4r's Avatar
5 Year Member
I recently went through replacing mine with a new OEM one sourced from the middle east. I took the old one apart and it was a bit gooey inside but probably would have been fine after cleaning. I think i kept all the old parts. If you want it, it’s yours for the cost of postage. I’ll have to check in the garage and find it Saturday.
Old Feb 16, 2022 | 06:47 PM
jaskotmb's Avatar
That would be awesome if you can find it! Would be really nice to have good brakes here in Colorado in the winter
Old Feb 17, 2022 | 07:47 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I took mine apart, and like Melrose, it was pretty full of old sludgy fluid. but it cleaned up well.
And your assumption about the bleeder screw is pretty accurate. Essentially just a bolt with a conical end. No hole. I think the revised LSPV has a single, more conventional bleeder.
Old Feb 17, 2022 | 08:20 AM
mechkw's Avatar
I've got one up for grabs from a parted out '87 4 runner with the arm still attached
B4Runner
Apr 4, 2010 11:54 AM
DanStew
Apr 3, 2010 12:52 PM
Yotaman666
Sep 25, 2009 01:36 PM
Scooby098
Oct 2, 2008 10:57 PM
bigdaddygreen
Feb 19, 2008 12:11 PM
