Code 24 and 31 help me 3.0 95 runner
Old Mar 19, 2022 | 06:18 PM
dawgmeatpizza's Avatar
Angry Code 24 and 31 help me 3.0 95 runner
I have recently bought a 95 4Runner and it had a gnarly surging idle. So naturally I had thought IAC/Throttle body needed a good ol' cleanin. Well I had took the throttle off and took the TPS off and cleaned said throttle/IAC put the TPS on in spec. Well now it wont even start. Unplug AFM and it starts right up but give some beans on the gas and it dies. I get the AFM remanufactured through Rock Auto/Cardone, I slap it on , truck fires right up but still rough and surging. I put it in drive, goes like 7 feet and dies. I jump the DIAG thingy get code 24 and 31. So now I'm stuck. I'm getting fuel/spark. Distributor is in time. Timing chain is in time.
Old Mar 19, 2022 | 10:48 PM
moto809's Avatar
5 Year Member
Well there are your starting points. Google codes 24 and 31 for a 3VZ-E.
Old Mar 20, 2022 | 01:32 PM
scope103's Avatar
What do those codes have in common? The connector to the VAF. Your VAF is probably fine, but you should test it to be sure. http://web.archive.org/web/201003261...92volumeai.pdf You probably have a problem in the wiring to the connector.
Old Mar 20, 2022 | 04:02 PM
how would one go about checking the connector? AFM is good.
Old Mar 20, 2022 | 05:00 PM
scope103's Avatar
Same way you tested the VAF, just do it from the ECM connector. http://web.archive.org/web/201003261...e/102engin.pdf
[Do reset the codes by removing the EFI fuse for about 30 seconds. These could be stored codes left over from when you changed the VAF.]
Old Mar 21, 2022 | 03:05 AM
Jonesy300's Avatar
Check my post from about 2 weeks ago.. I have the same damn problem
Old Mar 21, 2022 | 06:59 AM
Talking
roger that chief thanks!
FireFinder
Sep 1, 2014 06:08 AM
2000taco
Feb 21, 2013 03:05 PM
Ned
Sep 5, 2011 04:58 PM
Chuki
Jul 20, 2006 03:01 PM
