tick-tick-tick
Old Jan 30, 2006 | 09:36 PM
Brendan's Avatar
tick-tick-tick
my 92 22re makes a ticking noise strikingly similar to the noise it made when the timing chain was making before it was replaced. the noise is most prevalent at cold starts, on hills, and when i'm heavy on the accelerator. i removed the valve cover and the guides are perfectly in tact. before i changed the timing chain, i could rev up to 2250 in neutral and hear the ticking noise constantly whereas now, the noise cannot be heard in neutral at all. ideas?
Old Jan 30, 2006 | 09:57 PM
Yota4runner's Avatar
Could it be Valve tick? have you adjusted them at all?
Old Jan 31, 2006 | 06:30 AM
jukeit's Avatar
I'm new to Toyotas so I don't know if this applies, but with other vehicles I'm more familiar with that sound could be caused by your lifters. My friend's older truck does the same thing when climbing hills or putting strain on the engine.
Old Feb 15, 2006 | 10:43 PM
Brendan's Avatar
the valves were adjust about 12-18 months ago, but very little mileage has been put on since then.
Old Feb 16, 2006 | 03:43 PM
trx125's Avatar
Engine Pinging!
Old Feb 16, 2006 | 04:29 PM
hockeybird's Avatar
Probably just valves...mine tick also, but I hear its normal for the 22re and nothing to worry about.
Old Feb 16, 2006 | 06:04 PM
kyle_22r's Avatar
i can almost guarantee it's an exhaust leak.
Old Feb 16, 2006 | 06:55 PM
Brendan's Avatar
really? cuz my muffler is on it's last legs and it could very well be leaking from somewhere else as well. that'd be sweet if that's all it was.
Old Feb 16, 2006 | 06:58 PM
Brendan's Avatar
Originally Posted by trx125
Engine Pinging!
that thought had crossed my mind about a month ago. i've been through a full tank of 92 octane with no different results.
Old Feb 18, 2006 | 09:28 AM
kyle_22r's Avatar
the reason i think that's an exhaust leak is that it only occurs when the engine is cold(manifold/head aren't expanded and compressing the gasket fully, which helps seal the leak), and under load(more exhaust pressure seeping out). mine's got a nasty exhaust leak from having one of the manifold studs being cracked off, as well as both air injection tube bolts broken off inside the manifold. it's a mess.
Joey Link
Dec 29, 2009 08:14 PM
