A/C faceplate interchangability
Old Jan 30, 2006 | 04:22 AM
87rustbucket's Avatar
i need a replacement faceplate for my a/c panel which is cracked. I found a white faced one but it is avertised for a 89-91 toyota pickup. will this pannel fit my 87? if so what glue do i use to attach it. thanks...
Old Jan 30, 2006 | 04:43 AM
rocket's Avatar
You mean this...
http://cgi.ebay.com/ebaymotors/TOYOT...spagenameZWDVW
or this...
or...
http://cgi.ebay.com/ebaymotors/heate...spagenameZWDVW
Old Jan 30, 2006 | 06:18 AM
Dr.Feelgood's Avatar
I've seen the white-faced one you're talking about. Stupidly I ordered it because it said "89-91" but when it got here it wasn't. It was the one for your truck. I've since sold it. The seller, "glow-gauges" was told about it by more than myself but they never changed the description. If it looks like the one in the second link from Rocket, then that's the one for your truck. The white ones have 3M tape on the backside for mounting.
Old Jan 30, 2006 | 12:38 PM
87TurboYota's Avatar
You shouldn't need any glue. They pop into place you can pry them off from the right side. And probably should use a screwdriver to pry the tabs into place to put the new one on.
Old Jan 30, 2006 | 01:52 PM
im not talking about the whole plastic peice, im talking about the thin peice that has the writing on it. here is the product:pannel
Old Jan 30, 2006 | 04:10 PM
rocket's Avatar
uh...i think were all talking about the same thing.
Just buy one of the ones in the links i posted above.
Old Jan 30, 2006 | 04:38 PM
Rustbucket, that's the right glow panel for your truck. It has 3M tape on the backside to adhere to your stock panel. You can tie the wiring in to your dash lights and it will dim/brighten with your dash lights. Very simple to install.
Badlander
Oct 10, 2015 08:05 PM
Ktm526
Oct 7, 2015 05:14 AM
bryan34w
12
Sep 30, 2015 02:50 PM
icentropy
Sep 10, 2015 05:03 AM
Tacoma1313
Sep 8, 2015 01:27 PM
