My match up marks for the front diff and propeller shaft are missing... help please
Old Jan 28, 2006 | 09:21 PM
YotaJunky's Avatar
Well, unfortunately the match up marks for the front differential and the propeller shaft were smudged off during the process of reassembly.
What could possibly happen if I don't have them on properly? If they're not on the right way, how can I correct it?
The driver's drive shaft, lower A-arm, along with the ball joint were dropped because we had some challenges getting the front differential out. But after I put everything back together today, I'm noticing that when I turn right, there's a chaffing sound coming from the left front side. Could this possibly be a symptom of an improperly assembled propeller shaft to front differential issue, or is something else going on?
Troy
Old Jan 28, 2006 | 10:10 PM
Glenn's Avatar
Vibration will occur if it is out of phase with the hubs locked. It's easy enough to fix if there is vibration--just take it apart and reattach it turned ¼ turn and test drive. If the vibration is still there, turn it another ¼ turn and reattach. That should fix any vibration resulting from the mismatch.
Old Jan 29, 2006 | 03:03 AM
YotaJunky's Avatar
Thanks Glenn!
Troy
Daneums
Aug 20, 2015 05:36 AM
jaretstuff
Aug 4, 2015 02:08 PM
scottyg486
Jul 19, 2015 05:34 PM
TokyoD23
Jul 12, 2015 06:01 AM
crashburnoveride
Jul 10, 2015 06:39 AM
