ADD to Manual Hubs
Old Jan 24, 2006 | 09:46 AM
johnperrone11's Avatar
ADD to Manual Hubs
I did a search on this subject and found lots of info, but still no answer to the question: Do I have to do the Spindle Nut Conversion when going from ADD to Aisin Manual Hubs, or can I just slap in the new hubs and go?
Old Jan 24, 2006 | 10:04 AM
'94Runner4WD's Avatar
Just take off the ADD flange and the new hubs should slap right on.
Old Jan 24, 2006 | 10:07 AM
snap-on's Avatar
^^^^^ what he said
Old Jan 24, 2006 | 10:59 AM
Sweeet, thanks guys.
Old Jan 24, 2006 | 03:07 PM
Flamedx4's Avatar
Don't forget to do the spindle gear reversal and install new circlip retainer bearings.
Old Jan 24, 2006 | 05:13 PM
leebee's Avatar
thanks phil, that explains why mine has been running in reverse!
lee
Old Jan 25, 2006 | 08:48 AM
AHH yes, spindle gear reversal.... How do I do that?
Forgive me, I'm still a fairly new yota owner, and this is the first vehicle I've ever owned w/ IFS.
Old Jan 25, 2006 | 01:28 PM
Flamedx4's Avatar
Heehee. Just pullin yer leg.
Everybody knows you only gotta do the spindle gear reversal when you use a Dana 44 reverse rotation axle for your SAS....
Old Jan 25, 2006 | 02:35 PM
RustBucket's Avatar
It's a piece of cake. Just an echo - no you don't need the spindle nut conversion kit.
Old Jan 25, 2006 | 03:00 PM
leebee's Avatar
hey phil!!
looks like we had a live one there!
lee
Old Jan 26, 2006 | 09:31 AM
Okay, Okay... Lets not pick on the new guy too much.
So no conversions, just slap 'em on and go.
Sounds good.
Old Jan 26, 2006 | 09:55 AM
Flamedx4's Avatar
Yep, the only time you have to do the spindle nut conversion is if you are going from auto hubs to manual. ADD to manual is a snap. Takes longer to R&R the tires than to do the hubs.
Old Jan 27, 2006 | 03:11 PM
AUYota's Avatar
IS it a GOOD IDEA to replace the ADD to man. hubs? pros and cons??
Old Jan 27, 2006 | 03:17 PM
cootees's Avatar
Very good idea. Manual hubs will give you less wear on your cv shafts. plus maybe a hint of better gas mileage. That is enough pro's to make anyone want to do it. Less wear = less breakage.
Only con is you have to get out of your truck to lock the front wheels in 4wd.
Old Jan 27, 2006 | 08:28 PM
91_4x4runner's Avatar
Soon as I get the money, I think I'm going to do the ADD defeat and then convert to manual hubs. Money is the root of all evil
Old Jan 28, 2006 | 01:12 AM
leebee's Avatar
no need to defeat the existing system, just bolt the aisin's on and youre good to go.
lee
Old Jan 28, 2006 | 05:30 AM
The issue is that my ADD is starting to fail I believe. It only enguages in 4WD 1/2 the time and I believe its related to the ADD system.
http://www.4x4wire.com/toyota/tech/add/
Old Jan 28, 2006 | 07:42 AM
91,
I think the Aisin's would remedy your problem. I'm doing it simply because I hate changing CV axles. If the manual hub will save me from doing another CV just once, they've paid for themselves x's 10. Keep and eye on e-bay. Sometimes there's some good deals. But don't pay more than $40 for them on ebay, because the yotayard sells them for that, plus $10-$15 shipping.
Old Jan 28, 2006 | 08:05 AM
Dr.Feelgood's Avatar
Here's a question: if after doing the swap to manual hubs (which I'm starting about10 minutes), if you leave the hubs free and pull your lever into 4-Lo, does that essentially give you 2-Lo?
Old Jan 28, 2006 | 04:00 PM
If you leave the front hubs unlocked, yeah i imagine.
