Ignition Key lock
Old Aug 30, 2020 | 01:50 PM
ZARTT's Avatar
Ignition Key lock
What kind of device is used to lock the key into the ignition switch?
My daughters 1995 4Runner 6 cylinder automatic trans. decided out of the blue to not give up the ignition key upon shutting off the ignition.
The switch will turn about 1/2 way to the full off/lock position, and then stop there, not letting the key loose.
The engine shuts off, but the key is trapped.
I know that it is electrical in nature, as I disconnected the battery, and the ign. sw. will then go to full off position and release the key.
Hook the batt. back up and we are once again trapped.
It makes no diff. what gear the shifter is indicating.
It makes no diff. whether the engine is running or stopped when the switch sequence is initiated.
Can someone point me in the right direction?
Art.
Old Aug 30, 2020 | 01:53 PM
ZARTT's Avatar
The neutral safety system works. The only positions the starter will work is P, and N, no others
Old Aug 30, 2020 | 05:04 PM
scope103's Avatar
My guess is the shift lock control switch is not working (broken), or is not getting actuated by the shifter. http://web.archive.org/web/201408160...55shiftloc.pdf Get out the ol' multimeter!
(of course, it could be a mechanical problem in the column. I'd start with the FSM diagnostics given above.)
Old Aug 31, 2020 | 09:39 PM
STERFRY333's Avatar
damn I wish my key locked in always falls out whenever I go over a speed bump lol.
Old Sep 1, 2020 | 10:36 AM
ZARTT's Avatar
Scope:
Thank you!!
The V.O.M. is our friend.
Many ohms, or Zero ohms, both are clues.
Another ongoing condition with the Runner, that I overlooked, was that the shifter lock had never worked as it should.
The brake pedal never had to be depressed to move the shifter out of the park position.
It had been like that for years.
A workaround with a wiring change has been temporarily put into place.
An OEM perm. fix will be applied shortly.
Art
Old Sep 2, 2020 | 05:28 PM
ZARTT's Avatar
Didn't need to do a wiring change. Just pull the cig. fuse in the lower left kick panel fuse box.
77lubr
Aug 22, 2018 12:17 AM
g3bill2
May 2, 2015 02:28 PM
ASU4runner
14
Jul 15, 2012 12:44 PM
2 da max
Jul 10, 2012 11:31 AM
txrider
Dec 8, 2009 10:02 AM
