What is a 1-ton?
Old Oct 28, 2020 | 12:42 PM
MichaelKLerner's Avatar
What is a 1-ton?
I have an 88 pickup, 2wd, carbureted. I am hoping someone can tell me the important differences between my pickup and a 1-ton because I would like to, eventually, upgrade to 1-ton in all the important ways.
So far, I have changed to the 8-inch rear end (4.10:1), which means that I also have the drum brakes that are standard on a 1-ton. The leaf springs are rebuilt and re-arched using a 1-ton main leaf.
Shocks are KYB gas heavy duty (not off-road) all the way around.
Front torsion bars are new heavy duty units.
All else is original.
If you have any recommendations, please chime in.
​​​​​​Thanks in advance
Mike
Old Oct 28, 2020 | 02:02 PM
Jimkola's Avatar
YT Community Team
5 Year Member
Bigger brakes, higher gears, and thicker axles. When we did a few of the RV recalls where the RV company was defunct Toyota would ship a entire 1ton axle assy with diff. Also a full set of rims. The thicker axles were essential, this was the most common failure on the RV units.
im sure there’s more, Maybe U-joints?
Old Oct 29, 2020 | 02:01 AM
13Swords's Avatar
5 Year Member
You have this post up three times in this section. You might want to delete the other two.
Old Oct 29, 2020 | 04:28 AM
old87yota's Avatar
Only a moderator can delete regular threads.
MichaelKLerner
Oct 28, 2020 12:43 PM
MichaelKLerner
Oct 28, 2020 12:33 PM
Chris_McCartney
Jan 15, 2015 09:08 AM
GOTBOOST
May 31, 2008 06:16 PM
TJ95T100DX
Jan 5, 2005 06:05 AM
