Firewall passthrough 87 Pickup
87 Regular cab pickup trying to get a cable through the firewall and can't find anything obvious. Just need 1 cable for an amplifier and I'm doing this for a friend of mine. Any place existing or does a new hole need to be cut?
Opening in inner fender next to fuse block, bundle runs along inside of wheel-well, to opening into cab above or around the ECU. Similar on driver side.
Access by removing wheel-well shroud. 10-mm sockets, of course
Have electrical tape handy to re-tape the grommet/seal.
https://lh3.googleusercontent.com/wm...-no?authuser=1
Opening in inner fender next to fuse block, bundle runs along inside of whell, to opening into cab above or around the ECU. Similar on driver side.
Op is presumptively trying to run a power wire for a high current amp. Cut an X in a rubber grommet, like the engine harness seal, run your wire through it zip tie it on the inside and out side of the grommet, then flood the X with silicone or liquid tape..
