thwup thwup thwup... what's wrong?
Old Sep 3, 2007 | 06:58 AM
JohnStra's Avatar
When I start my truck it sounds like it's hitting on 2 cylinders... thwup thwup thwup. I give it throttle and it eventually smoothes out and runs normal. Once it smoothes out it runs just fine. TPS? Throttle body? Something else?
Thanks for any suggestions!
-john
Old Sep 3, 2007 | 08:03 AM
TNRabbit's Avatar
I'd guess you have a bad spark plug, but I'd do a compression test, pull all the plugs, and also check the injectors. Start from there and let us know what you get...
Old Sep 3, 2007 | 11:24 AM
86tuning's Avatar
How is your coolant level?
If you're losing small amounts of coolant, it may be a bad head gasket allowing coolant to leak into a combustion chamber after the truck is shut off.
Steven.m.paulk
Jun 7, 2020 10:45 AM
zytra
Jan 24, 2019 03:16 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
charlie_fong
Sep 27, 2015 10:06 PM
