testing fan
Old Aug 26, 2007 | 04:17 PM
Kiff's Avatar
testing fan
So I think I may have figured out my over cooling issue, I believe my fan is not free wheeling. How am I able to test out if my fan clutch free spins or is sticking? When the motor is turned off the fan does spin, but with a fair resistance.
Old Aug 26, 2007 | 04:21 PM
frodin1's Avatar
Did you try spinning it? You can usually tell if the clutch is messed up. It shouldn't spinn freely, but should spin.
Old Aug 26, 2007 | 04:23 PM
frodin1's Avatar
Over cooling is usually contributed to a thermostat issue. Have you changed it out, or do you know what temp it's supposed to work?
Old Aug 26, 2007 | 04:38 PM
Kiff's Avatar
Yes I have already changed out my thermo. I am betting on the fan because, only at higher speeds do I get the over cooling effect. when the trans shifts out of O/D and the motor sits at the higher RPM the temp really starts to drop.
Old Aug 26, 2007 | 04:41 PM
frodin1's Avatar
That's wierd because you can usually tell the fan clutch is bad, but I suppose it could only be acting up at higher speeds.
Old Aug 27, 2007 | 08:55 AM
Kiff's Avatar
anyone else have ways of testing the clutch?
_Nicco_
Sep 21, 2015 03:06 PM
Kreedy1
Sep 8, 2015 06:33 PM
AkitaDog
Sep 3, 2015 09:01 PM
128keaton
Sep 3, 2015 05:09 PM
Aaron Logan
Sep 3, 2015 08:08 AM
