95 4runner blower not working properly??
Old Aug 21, 2007 | 01:36 PM
cracker_1's Avatar
I recently bought a 95 4runner. The A/C works on low only. When I swithch to a higher fan mode, nothing happens. The system shuts off. Is this a common problem? The A/C and heater only work on low. So, on HOT days, I have to keep the A/C on low to keep the runner somewhat cool inside. It blows cold air, just not ENOUGH!!!
Old Aug 21, 2007 | 02:03 PM
Dublin's Avatar
It's either the resistor or fan switch. If it's the switch it usually will not operate smoothly thru its range, if it's the resistor this will help. http://www.4crawler.com/4x4/CheapTricks/Blower.shtml
Old Aug 21, 2007 | 02:27 PM
cracker_1's Avatar
Originally Posted by Dublin
It's either the resistor or fan switch. If it's the switch it usually will not operate smoothly thru its range, if it's the resiastor this will help. http://www.4crawler.com/4x4/CheapTricks/Blower.shtml
Thanks for the info, but after reading the article, it looks like that is not my current problem. According to the article, if the resistor fails, only high speed will work. I only have the low speed working, no medium or high. So, I am going to pull the switch out and see what I can find out.....
Old Aug 21, 2007 | 02:35 PM
tc's Avatar
tc
Depends on which part of the resistor pack goes - NORMALLY you only have high, but if any of the segments goes you'll lose that "zone". They're easy and cheap to replace, be sure to check it out.
Old Aug 21, 2007 | 02:38 PM
cracker_1's Avatar
Thanks, I will check the resistor out. Is it located on the firewall as described in the other thread?
Old Aug 21, 2007 | 02:43 PM
Farmerunner's Avatar
Definitely check the resister. It sounds to me like you have the exact same problem I had on my F-150. It isn't a Yota, but I am sure they are built the same way.
The replacement resister was a cheap and easy fix....much better then living with only low. Wait till you need your defroster and you only have low, it can be dangerous.
Old Aug 27, 2007 | 09:33 AM
cracker_1's Avatar
Well, the resistor would be an easy fix, but it is not CHEAP. I was quoted thru Toyota a cost of $85 for the resistor. Thankfully, I declined and decided to take the switch apart. The switch had fallen apart, I put it back together and everything works as it should. Lucky there....
Old Aug 27, 2007 | 10:33 AM
BluYot's Avatar
Ah, that explains alot....I was washing some road crap off my truck in the winter and for some reason right after I was done, started it up and the fan wasn't working....only on high!? I thought it was moisture getting in...I'll have to look. Weird.
JF9243176
Oct 8, 2017 04:21 AM
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
JF9243176
Jun 24, 2015 04:53 AM
gog1968
Jun 22, 2015 05:55 AM
