ifs rear truss ?
ifs rear truss ?
hello first post .
the question is is it better to bolt in a rear ifs truss or weld it in ?
if welded dose it get in the way of fixing or removing should anything need to be fixed or removed .
great site read it every day .
in some of the searchs i did some guys were welding them in , i hear ya with the bolt in part being abel to remove it to work on front diff but can the diff still be worked on or removed with the truss in place ,it is tight under there with the truss in ,some companys also offer it as weld in .
i am building this myself and have not fabbed up the mounting part yet the rest of it is done, kinda steeling ideas from what i seen on here .
I'd say bolt it in. The stresses on it should be mostly compression/tension, unless you're hangin it on rocks. There won't be much twisting down there involved. And if there is, chances are shearing some bolts aren't going to be your main problem.
Flying91
45
04-11-2024 04:39 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
scottyg486
07-19-2015 05:34 PM
