How do you remove a tapered washer?
Old Aug 25, 2007 | 10:29 AM
shoff's Avatar
I have an 86 4runner and I am trying to replace/check the front wheel bearing. It is a 4wd and I am stuck at the tapered washers that hold on the part that switches it from 2wd to 4wd. HOW DO YOU REMOVE THIS THING?
Old Aug 25, 2007 | 10:32 AM
MMA_Alex's Avatar
cone washers? penetrating oil (pb blaster) and a couple good blows with a hammer
Old Aug 25, 2007 | 10:53 AM
TORTIS's Avatar
back the nut back to the edge of the threads and get a punch or a big nail. put your punch on the center of the bolt and hit it a few times, easy. then take the nut off, and get a pair of pliers and twist the cone washer out, if it does not want to come out put nut back and hit it a few more times. the nut being on keeps the nut from expanding. when you go to put the cone washers back on coat them with anti-seize.
Old Aug 25, 2007 | 12:54 PM
tc's Avatar
tc
I give the stud a firm rap with a brass drift. I have the best luck with working my way around the hub - don't just sit and wail on one of them. If you're having real trouble, sometimes a few whacks on the side of the hub will help, but that's kinda a last resort - you don't want to damage the hub!
Once you get one to pop loose, the rest come pretty easy.
Old Aug 25, 2007 | 02:50 PM
CyMoN's Avatar
https://www.yotatech.com/forums/f120...remove-122244/
Old Aug 25, 2007 | 04:16 PM
waskillywabbit's Avatar
PB is a good idea. Hitting the studs or the hubs directly with a hammer is a bad idea.
Do not use a punch as it will damage the studs (they are not bolts). Use something brass as it is soft and will take the blow and transfer it to the studs without damaging them.
Yes. Use the brass drift to transfer the blow from the hammer to the stud of the manual hub as the brass is softer and will not damage the studs or hub. Removing cone washers is more finesse than gorilla force...and the former leaves your studs and hub in much better shape. I've seen what ignorant gorillas do to hubs as I've purchased quite a few used sets and you can easily tell who knew how to get cone washers off and who did not.
Some good stuff there as well.
Old Aug 29, 2007 | 06:14 PM
rustypigeon's Avatar
There is a much easier way than hammering on the studs... I made a tool from a 3/32" punch (a 1/8 punch should work too) file the tip of it so the edge looks like a chisel. Spray a bit of penetrating oil in the gap of the cone washer and let sit for a few minutes. Then take your modified punch and put the end in the gap of the cone washer. Give it a couple of taps with a hammer and the cone washer will pop out from the expansion by the punch.
I tried hammering the studs before and I could not get the cone washers to come off. The modified punch works so well that I can get the washers off with 1 or 2 smart taps with a hammer. Try it, you'll like it!
Old Aug 29, 2007 | 06:30 PM
YotaJunky's Avatar
x1000 on using a brass drift before you go to town on the studs. They could really get messed up otherwise.
Troy
Old Aug 30, 2007 | 10:37 AM
drew303's Avatar
I lightly tap the hub all around and it wiggles them all out..
Old Aug 30, 2007 | 12:43 PM
Intrepid's Avatar
I use the hub tapping method some, but I get a small screw driver, put it into the crack in the cone washer, then wack it with a hammer until it sinks enough to touch the hub itself. If that hasn't loosened it enough, I move on to a bigger screwdriver.
Old Aug 30, 2007 | 02:23 PM
4Crawler's Avatar
Some other ideas:
- http://www.4crawler.com/4x4/CheapTri...eWasherRemoval
Marsheen
Feb 17, 2016 12:29 PM
A2theK
Sep 4, 2015 03:16 PM
trailgoat
Aug 13, 2015 05:54 PM
Gone Fission
Jul 24, 2015 12:49 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
