Using Coke - Coca~Cola in the water jackets of an engine block.
Old May 17, 2013 | 11:56 AM
mikesta's Avatar
I've seen this done in the past and am wondering if anyone here has done it. Coke is definitely useful for other things, like disintegrating pennies and I believe people pour coke in the water jackets (when the head is off) to clean the water jackets out. Anyone here hear of this?
I thought about titling this thread 'Any Coke users here' but decided against it
Old May 17, 2013 | 02:43 PM
Inu's Avatar
Inu
I would just stick with nylon stiff bristle cleaners and water. Or the machine shops power tank when i can afford it.
Old May 18, 2013 | 09:59 PM
Alaska90's Avatar
Nothing magic about coke. It's phosphoric acid in it that cleans/eats things. You could make up a weak batch of phosphoric acid. You can google for suggestions on how to use it to remove rust.
Coke, other than water, is mostly sugar. Can't imagine it's a good idea to let sugar into the block.
Old May 18, 2013 | 10:09 PM
brianh699's Avatar
I've heard they use coca-cola to clean the engines @ coke distribution centers, could be BS but it will dissolve steel and works great on steel wool removing rust.
Old May 19, 2013 | 08:12 PM
TNRabbit's Avatar
Looks like CLR would be the best alternative, since it's made to dissolve calcium, lime & rust~
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Jonny246
Jul 12, 2015 04:51 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Gamble_STi
Jul 7, 2015 07:54 PM
