Crankshaft help. 94 22RE
Old May 17, 2013 | 11:55 AM
branw97469's Avatar
So I picked up a 1994 22RE that had a spun rod bearing. I bought a new crank for it with matching bearings and assembled it. I could turn the crank just fine with the mains torqued. And it turns fine with all the rods torqued except for #2. Well at first it wouldn't turn at all so i took it all apart and cleaned both sides of both rod bearings and reassembled with minimal lube. It turns now but it's not as easy as I was hoping. Somethings not right and i need some pointers.
Old May 17, 2013 | 12:07 PM
85TurboRunner's Avatar
Did you use plasti gauge?
Old May 17, 2013 | 12:09 PM
branw97469's Avatar
Yep. Everything was in clearance.
Old May 17, 2013 | 01:21 PM
scope103's Avatar
You might have a bent piston rod. I don't really know how to check them; I know there exists a precision jig for that purpose. You might try rubbing a little lampblack (or graphite) on the journal and see if it wipes more on one side when you turn the crank one time.
Old May 17, 2013 | 02:31 PM
branw97469's Avatar
Well I just went through a set of rod caps I had laying here from another motor(9k on a rebuild) and measured then out until I found one that was just a tad smaller. And it works great. The crank spins free but has enough drag to tell me it's not too loose somewhere.
jasonty
41
Dec 23, 2018 01:00 PM
Linked2002
3.4 Swaps
7
Dec 15, 2015 01:31 PM
redneck17
Aug 12, 2015 08:15 PM
bryan34w
Jul 6, 2015 05:53 PM
