22RE Light knock at 12-1300 rpm when warm
Old May 8, 2013 | 03:18 PM
chwkrx7's Avatar
Hey all,
I have an 89 RE with about 20xxx miles on a rebuild that I've had in storage for the last year. I just pulled it out two weeks ago, and since driving it i've had a slight knocking noise at around 1300 rpm, goes away (or at least seems to) when I rev it up. If it's hot you can barely hear it at idle as well.
Doesn't do it at all cold. Anyone had this before? I just did an oil change with 500ml of Lucas Oil Stabilizer and the rest ACDelco 15W40.
Cheers
Old May 8, 2013 | 03:30 PM
bone collector's Avatar
check the valve lash
Old May 8, 2013 | 06:38 PM
abecedarian's Avatar
... and ignition advance.
... and oil weight.
Old May 13, 2013 | 09:46 PM
chwkrx7's Avatar
Good suggestions.
Checked valve lash. All ok.
Checked ignition avance. All ok.
Oil weight is 15w40
Starting to think maybe it is bottom end. It's just weird how it doesn't do it on accel, only decel and cruise. Load it up and the noise goes away. I took a look at the chain and guides too, they look ok. Here's a video of the noise. Excuse the oil everywhere, I has it running with the valve cover off.
Old May 14, 2013 | 02:21 AM
J_yota22k's Avatar
did you check and make sure your header are not crack? my did that same nosie and found out i had to replace my header then that noise went away
Old May 14, 2013 | 02:22 AM
J_yota22k's Avatar
other then that check your valve lash make sure everything tighten down
Old May 14, 2013 | 07:11 PM
94toy22re's Avatar
I had the same issue a few months back, valves where to tight!!
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
