Timing chain grind.......
Old May 16, 2013 | 11:09 AM
woodyth's Avatar
I have had this noise since I bought the truck 2 years ago. Just recently it has gotten worse. It used to be my sign that i was low on oil, it would get worse but when I'd add a half a quart, it would go away. Now it's the constant grind, so I think it's time to tear in to it. Is it better to go to Toyota for these parts, or a place like lcengineering.com? I have never done one of these, so this will be an "experience" to say the least. ANY advice would be GREATLY appreciated!
Thanks,
Woody
Old May 16, 2013 | 02:49 PM
stanprophet's Avatar
Just in luck just posted the pictures of the one I did today.
https://www.yotatech.com/forums/f116.../#post52077789
Parts go to EPN also known as engnbldr on ebay for the parts, I found it cheaper through his web site than ebay.
http://www.engnbldr.com/
You can pull the valve cover gasket and make sure the drivers side guide is broken, if it is it is time.
Old May 18, 2013 | 05:41 AM
woodyth's Avatar
any issues with parts from there?
Old May 18, 2013 | 01:41 PM
Nope, fit and finish were great. The tensioner is OEM manufacturer, everything seemed to be better quality than the average parts store parts. But the price is much cheaper.
Old May 20, 2013 | 06:03 PM
woodyth's Avatar
parts ordered guy was nice enough. put up with my 20 questions lol 149.99 not bad!
Old May 24, 2013 | 09:27 PM
woodyth's Avatar
Chain replaced. water and oil pumps also. I'm AMAZED at how simple it was.... I just followed the instructions here:
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
Great write up step by step!
Next is the clutch in 6 weeks................
Old May 25, 2013 | 05:10 AM
jumper_bob's Avatar
Hi Woody, I also just did that same repair using the engnbldr front end kit ($149) and the same instructions as you. Time consuming, but not difficult.
I just read another thread and realized that I didnt use any sealant on the timing cover gasket; everything I used seemed to fit well and snug and I havent noticed any leaks yet; hopefully I wont need to tear it apart and put a new gasket in with sealant. Did you use sealant around that gasket?
Old May 25, 2013 | 08:54 AM
woodyth's Avatar
I didnt use any, just on the corners on top and along the oil pan on the bottom......
Old May 25, 2013 | 05:16 PM
woodyth's Avatar
Maybe someone with more experience can chime in on this!?!?!??!?!
Old May 25, 2013 | 05:21 PM
Toyota~Boy's Avatar
I've always used sealant on every inch of the timing cover. If not then I almost grant you it will leak. Or mine always did.
Old May 27, 2013 | 06:08 PM
woodyth's Avatar
I'm gonna keep a close eye vs tearing it all down again......
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
razorman8669
Jul 12, 2015 12:13 PM
