im beating a dead horse
Old May 13, 2013 | 07:04 PM
wolf28's Avatar
Red face im beating a dead horse
I posted before about a headlight upgrade about hids and I read I needed a wiring harness.. well after doing a search I found out I can get e-code headlights and run an h4 bulb I found these on amazon
AutoPal Euro Clear H6054 7x6 Inch 200mm Headlights Pair H4 Bulbs Non-Sealed H6014/H6052/H6054 : Amazon.com : Automotive AutoPal Euro Clear H6054 7x6 Inch 200mm Headlights Pair H4 Bulbs Non-Sealed H6014/H6052/H6054 : Amazon.com : Automotive
im wondering are these just plug and go or do I need a harness for these also
Old May 13, 2013 | 07:44 PM
SkybluYota's Avatar
Not to be a jerk, which are abundant on public forums, but on the first line under "Product Features"
-Fits H6014/H6052/H6054 sealed beam socket - Plug and Play=
According to Amazon anyway, looks like plug & play. Id be wary of quality though. Ive seen some crappy amazon/ebay lights
Old May 13, 2013 | 07:54 PM
wolf28's Avatar
oops miss read what lenses should I be looking for
then I heard hella was good
Old May 14, 2013 | 02:02 AM
TNRabbit's Avatar
Are they "hella" good?
Old May 14, 2013 | 06:09 AM
wolf28's Avatar
haha
don't wanna spend the money on the hellas
looking for a cheap housing that will get by and still have good light output
Old May 14, 2013 | 06:38 PM
wolf28's Avatar
Old May 15, 2013 | 12:39 AM
Co_94_PU's Avatar
There is a thread that covers all this very well already. you'll have to search it I forgot the title.
In short yes they will plug right in, in most cases, but you won't be getting the full upgrade benifit w/o the wiring upgrade.
Old May 15, 2013 | 12:55 AM
RAD4Runner's Avatar
Correct, bulb upgrade simply masks the problem, you also need to upgrade wiring to minimize voltage drops due to high resistance of thin and long wire.
Search for "H4 conversion". Also "H4 conversion harness" for plug-n play harness. Also go to 4Crawler's website and look for same.
Link on my sig compares voltages drops between stock and upgraded and details how I did mine using only one additional relay and thicker wires.
Old May 15, 2013 | 06:11 AM
wolf28's Avatar
well I found some these on ebay http://www.ebay.com/itm/200mm-H6054-H4-EURO-CONVERSION-HEADLIGHTS-KIT-/330897426583?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d0b060897&vxp=mtrI read in some posts that u don't need the harness and that 55/60 watt bulbs would work
Old May 15, 2013 | 08:40 AM
RAD4Runner's Avatar
Correct, you do not need the harness, those fixtures are plug- n play. The harness is an upgrade to minimize voltage drop (meaning power loss) in wiring as explained in my post, as well as other posts.
Old May 15, 2013 | 07:20 PM
wolf28's Avatar
so how high of a bulb can I run without the harness
Old May 15, 2013 | 07:26 PM
85gijunk4x4's Avatar
Not to be a jerk here as well, but I rode with a friend the other night who was showing me his best awesome top of the line lights that he had to run all crazy wire harnesses for, and they had a cool blue tint and shoot way out and really wide etc. etc.
My 2 year old foggy sealed beams did almost the same
Old May 15, 2013 | 07:29 PM
To each is own though, do as you please!
my $0.02 is to leave it alone and just get some upgraded sealed beams, as those fancy bulbs seem to get expensive when stuff goes wrong.
But I know nothing about headlights, so I cant really answer your question.
Old May 15, 2013 | 07:34 PM
wolf28's Avatar
wat kinda sealed beam would I get would like to do the h4 conversion
Old May 15, 2013 | 07:39 PM
I was going to get something like for my 88 sr5 before I realized that POS I sunk all my time and money into should be on fire in my yard right now, or in a junkyard.
I don't know how they are compared to other lights, because lke I said I don't know anything about lights but they seemed to be an upgrade.
http://www.summitracing.com/parts/grm-09-1081/overview/
Old May 15, 2013 | 07:40 PM
I guess you just plug an H4 bulb into it?
EDIT*** I guess that's pretty much what you're asking....if the wiring harness has to be changed to accommodate the H4 bulb
Old May 15, 2013 | 07:43 PM
Co_94_PU's Avatar
The stock wiring and wire routing is not even good enough for the stock bulbs, so you are better off upgradeing the harness and going with a "proper" relay system than spending cash on bulbs you won't be getting the maximum from.
You should check out RAD's link on the harness.
Old May 15, 2013 | 07:51 PM
wolf28's Avatar
well im getting these http://www.ebay.com/itm/200mm-H6054-H4-EURO-CONVERSION-HEADLIGHTS-KIT-/330897426583?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d0b060897&vxp=mtrand a harness but what harness do I need I see 4crawler has like 3-4 different 4h ones
Old May 16, 2013 | 11:40 AM
wolf28's Avatar
Old May 19, 2013 | 07:49 PM
wolf28's Avatar
any one tried the putco wire harness
smilen724
13
Nov 8, 2015 04:11 PM
Chicken12
Oct 14, 2015 03:54 PM
mreagen
Oct 5, 2015 04:27 PM
89YodaRunner
Sep 30, 2015 02:18 PM
Toys4parts
Sep 26, 2015 01:56 PM
