4rner gauge cluster removal ?'s
Old Dec 12, 2006 | 04:11 PM
mt4runner's Avatar
Gettin ready to replace my speedo cable in my '91 'runner, 5 sp V6. Can I remove the cluster w/out removing the steering wheel? Also, is it possible to access the cable at the speedo head without removing the cluster?
Regards, Rick
Old Dec 12, 2006 | 04:16 PM
spudrunner's Avatar
This may help.
https://www.yotatech.com/forums/f115/doing-sr-5-gauge-cluster-swap-how-pictures-51800/
Old Dec 12, 2006 | 04:18 PM
Elton's Avatar
https://www.yotatech.com/forums/f126/indiglo-gauge-installation-2nd-gen-4runner-75767/
Old Dec 12, 2006 | 04:53 PM
mt4runner's Avatar
Thanks guys! Big help. The only reference I have is a Chiltons manual, and it shows to pull the steering wheel + lots of other stuff. This won't be as bad as it first appeared.
Rick
Old Dec 17, 2006 | 12:57 PM
SpeedyManiac's Avatar
If the 91 is the same as my 89, then it's really easy and you don't have to remove the steering wheel. 5 machine screws hold the plastic fairing on, then another 4 hold the gauge cluster in place. Only tricky part is disconnecting the speedometer cable. Small hands would help.
Old Jan 17, 2008 | 11:36 AM
89RUNNERFFD's Avatar
I have installed an SR5 Cluster in my 89 4runner 1st gen. I know its from a v6 but not sure if its from an Auto or Manual. My Truck is an Auto.
My problems are
Fuel Gauge shows and is stuck at full
Speedo dose not work
Water Temp guage shoots up to overheat
mussy01
Dec 13, 2016 08:20 PM
gary4runner
Sep 24, 2015 12:53 AM
teknovls
Aug 9, 2015 12:37 AM
Esibnitsud
Jul 30, 2015 08:21 PM
