22ret Pistons
Old Dec 6, 2006 | 10:44 AM
RD1970's Avatar
22ret Pistons
Are 22ret Pistons Cast Or Forged From The Factory?
Old Dec 6, 2006 | 11:02 AM
Yota82's Avatar
cast.
Old Dec 6, 2006 | 11:08 AM
dcg9381's Avatar
If you want forged, you can do LC engineering, which sells CP Pistons..
(Note DOA and Rick at Fullboogie.net also sell 'em and may cut you a little better break)
Otherwise http://www.venolia.com/ - they do forged also.
Both vendors do custom exclusively - so they can do low compresson stuff.
Venolia is significantly less expensive than CP.
From what I've been told, the stock cast pistons - 22re / 22rte are good for about 200hp.
Old Dec 6, 2006 | 11:29 AM
Bill's Avatar
Engnbldr can also get you turbo pistons, for just a bit more than regular 22RE pistons.
Old Dec 7, 2006 | 11:17 AM
RD1970's Avatar
Has anyone here ever built a turbo 22r with engnbldr's parts? If so how did
you like it?
Old Dec 7, 2006 | 07:30 PM
drew303's Avatar
Check this site out RD1970
http://22returbo.net/
22RE to 22RE-T
So basically you can turbo a 22R, fuel inject it then turbo it. Thats what makes these engines so damn bad ass. So many possibilities! =)
Old Dec 7, 2006 | 07:32 PM
Elton's Avatar
engnbldr parts are great
Old Dec 8, 2006 | 07:31 AM
dcg9381's Avatar
you like it?
I've built a supercharged motor with engnbldr's parts, but CP pistons. It worked well. I highly recommend his stuff, assuming you keep the power levels reasonable. After 200hp, you need to go to forged pistons and things start gettting expensive.
I'd love to see a "budget" turbo motor and would support getting that done at a reasonable cost on the EFI side. 22RTE pistons into a 22RE block, EFI retune, t3/t4. Keep it under 200hp for reliablity.. It'd be like having 2x22re motors in the place of one, a stock 22RE only puts down about 80-90 RWHP.
Old Dec 10, 2006 | 05:01 PM
RD1970's Avatar
I plan on running 10psi of boost or lessand was told that engnbuilder pistons would hold up fine as long as I run an intercooler.
Has anyone ever put an intercooler on one of these trucks if so got any pics?
Old Dec 10, 2006 | 05:27 PM
dcg9381's Avatar
Jeff mosk has.. do a google search.
Firefightersink15
Nov 23, 2015 10:32 PM
charlie_fong
Sep 27, 2015 10:06 PM
sonorn67
Sep 19, 2015 05:39 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
old87yota
Sep 9, 2015 12:39 PM
