Vibration
Old Dec 17, 2006 | 11:29 AM
GreyHawk's Avatar
Vibration
I have replaced, tie rod ends, inner and outer wheel bearings, drag link, idler arm, pitman arm, shocks, alinement. I can hold the passenger wheel at 9 and 3 and get movement with a clicking sound. The wife said it sounds like metal on metal. Any Idea as to what to check again. With my hands at 12 and 6 no movement or sound.
Old Dec 25, 2006 | 04:38 AM
GreyHawk's Avatar
I found the problem. When I had the front-end alignment done the clamp on the passenger outer tie-rod end and sleeve was not on the threaded part of the tie-rod. There was movement within the sleeve. I tried to move the clamp and tighten it but the damage was done. I am going to replace the outer tie-rod end and sleeve and I hope that will fix it.
Old Dec 25, 2006 | 05:12 AM
mt_goat's Avatar
Wow... that could have been dangerious. Sounds like you were one good bump away from having one wheel not connected to the steering wheel.
Old Dec 25, 2006 | 05:41 AM
86SR522REEFI's Avatar
Make sure you let the shop know that too.
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
tinigunner11
Aug 14, 2015 01:19 PM
