Can't get my upper bumpstops off
Old Dec 8, 2006 | 11:39 AM
Fo by Fo's Avatar
So I have a 91 4runner 4wd and I got some low pro bumpstops, and as I was installing them I realized I couldnt get the stock upper ones off because they hit the control arm before the bolt was all the way out. The only reason for this I can think of is the torsion bar is over cranked. The guy I bought it from cranked them so much that the suspension was bottoming out on the upper bumpstop, so I un-cranked them some, but is it normal to have troube getting off the bumpstops?
Old Dec 8, 2006 | 11:42 AM
amgraham's Avatar
I assume you mean the droop stops. Try to have a couple people sit on the fender and see if that gives you enough room to sneak it out of there. Otherwise you will have to back off the torsion bars to do it.
Old Dec 8, 2006 | 12:44 PM
slosurfer's Avatar
use your bottle jack. turn it upside down, the bottom on the uca and the top on the lower bumpstop bracket. Watch your brakelines and your hands.
Old Dec 8, 2006 | 01:25 PM
MonsterMaxx's Avatar
Just jack up one side at a time pushing up on the lower a-arm. Should be plenty to get the upper snubber out
Old Dec 8, 2006 | 01:49 PM
ButtPirate's Avatar
i used to always have a buddy sit on the fender of the side i was working on. that seemed to make just enough room for it to sneak in and out.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
aowRS
Sep 13, 2017 08:22 AM
bradahman
Oct 1, 2015 09:24 AM
crash813
Sep 27, 2015 07:15 AM
Project90
Sep 24, 2015 11:40 PM
