Power Steering Box Rebuild
Old Dec 7, 2006 | 05:44 AM
amgraham's Avatar
I searched this and came up with a couple old threads with broken links. Does anyone have a link to a write-up on how to rebuild my steering box? It's leaking like a sieve. Also, where should I get the seal kit? trdparts4u has it for $82. Is that a good price? Any other sources? Thanks for the help! Vehicle specs are in my sig.
Old Dec 7, 2006 | 08:17 AM
4Rocker's Avatar
A few months ago the box on my 84 decided to start leaking on me. I looked at different rebuild kits and seal kits, as well as reman boxes from different sources (which are expensive as hell). In the end I decided to ebay a used box for about $150. Works great, and it bolted right up. From what I have read, some special tools are needed for rebuilding the boxes, and there are a lot of loose bearings inside if you take it apart wrong (trust me...).
Old Dec 7, 2006 | 08:32 AM
4Crawler's Avatar
Factory Service Manual would be helpful, or the old link is cached here:
http://web.archive.org/web/200503220.../taco/box.html
amgraham's Avatar
Well, yeah, I know I can get a used one. But, every IFS box I have looked at lately leaks to some extent and I would just like to learn how to do it.
Old Dec 7, 2006 | 08:35 AM
amgraham's Avatar
Thanks Roger. I wish the pics worked on that page. I have about every manual except for the factory one (Haynes, Bentley, Chilton). I don't think they had a good step by step in any of those as most people say to replace it.
Old Dec 7, 2006 | 08:10 PM
drew303's Avatar
check the pirate4x4 forum, the FAQ there has links to some detailed write ups on rebuilding the IFS steering box, its not to extreme.
I have a pdf copy of a scanned '85 repair manual ( 57mb ) but it has the '85 box in it. =/
probably similar rebuilds though
Old Dec 7, 2006 | 08:14 PM
UKMyers's Avatar
I'll be following this thread..mine is on it's last legs.. been leaking for a long time and been steadily getting worse. The other day it was whining everytime I turned the wheel until it warmed up. It's time to rebuild her.
Old Dec 7, 2006 | 09:09 PM
amgraham's Avatar
That's probably the power steering pump rather than the box.
I'll cruise around pirate and see what I can find. If I find some good info I will post it up here. Also, I think I have found a used box and I'm still going to rebuild it and then swap it out and keep my old one as a spare.
Old Oct 21, 2007 | 08:01 PM
86Original's Avatar
So did you ever rebuild your steering box? I have the seal replacement kit from toyotapartsales.com, but looking in the FSM that I have (purchased in 1989), it looks like you need some SST's to rebuild it. Any hints?
Old Oct 21, 2007 | 08:04 PM
4Crawler's Avatar
Pictures on that page work fine. Just give them time to load.
Here are some:
Old Oct 21, 2007 | 08:17 PM
WCorbett's Avatar
You can buy rebuilt hopped up ones from PSC and send them your old one for $250.
Old Oct 22, 2007 | 09:34 AM
86Original's Avatar
Any hints on how to go through it completely w/o spending hundreds on SSTs?
Does anyone know how to get off the nut on the end of the shaft that requires a odd large wrench?
BTW, The FSM link that 4Crawler listed above is dead...
Old Oct 22, 2007 | 01:55 PM
AUYota's Avatar
I'm not sure how much your time and safety is worth to you but a new/rebuilt one with a core charge is about 350-500 bucks... they won't leak PERIOD. Also like brakes you might want to consider leaving vital steering components to a profesional.
Old Oct 22, 2007 | 02:56 PM
MudHippy's Avatar
I've never needed an SST for anything, and as far as most people would say, I've completely "remanufactured" my 88 pickup. There's always a way to make one or use a different tool/method entirely. From browsing through the FSM(Here's a link to the 93 FSM: http://personal.utulsa.edu/~nathan-b...ng/13gearh.pdf) it looks like instead you could use line or socket/crescent wrenches for a couple of the hydraulic fittings, a brass drift pin and a hammer(or a slide hammer/seal puller)to knock out the cross shaft bearings from the housing, and a pair of pliers with protected jaws for the worm gear removal. And FYI, a block of wood or the right size socket installs seals just as good as any SST "seal installer". I'll bet ya a $100 I can rebuild one without using 1 SST. Mines not leaking that bad yet, but I need the money, so let me know.....
The large nut that holds the pitman arm to the cross shaft requires a 32mm socket, 1&1/4" socket is equivalent. And a gear puller or the hammer and drift method will remove the pitman arm from the cross shaft easily, sans SST.
Old Oct 22, 2007 | 06:00 PM
86Original's Avatar
Originally Posted by MudHippy
I've never needed an SST for anything, and as far as most people would say, I've completely "remanufactured" my 88 pickup. There's always a way to make one or use a different tool. From browsing through the FSM
(Here's a link to the 93 FSM: http://personal.utulsa.edu/~nathan-b...ng/13gearh.pdf) it looks like instead you could use line or socket/crescent wrenches for a couple of the hydraulic fittings, a brass drift and a hammer to knock out the output shaft bearings(or a slide hammer/seal puller), and a pair of pliers with protected jaws for the another. And FYI, a block of wood or the right size socket installs seals just as good as any SST "seal installer". I'll bet ya a $100 I can rebuild one without 1 SST. Mines not leaking that bad yet, but I need the money, so let me know.....
The large nut that holds the pitman arm onto the output shaft requires a 32mm socket, 1&1/4" socket is equivalent.
The SST that I'm most concerned about is the 09631-00030 & 09631-00040 combination that are used to take off and put on the lock nut on the adjusting screw that is on the worm gear shaft. Sounds like a bottom-bracket wrench for bicycles might work for that...
Old Jul 29, 2010 | 02:02 PM
mlrtime99's Avatar
Bumping this one back to the future... 4crawler, how the heck did you undo the stakes on the plate that holds the input shaft UP to the housing, I can tell it's aluminum but i can get anything small enough to hit it with enough force to bend them back.
Old Jul 29, 2010 | 02:17 PM
4Crawler's Avatar
Sorry, have never torn one apart before.
jerusry
Oct 19, 2015 05:28 PM
jon.r
Jul 11, 2015 03:34 PM
crashburnoveride
Jul 10, 2015 06:39 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 8, 2015 12:05 AM
