Correct Idle Setting Procedure
Old Dec 16, 2006 | 07:37 AM
wildman326's Avatar
I'm sure there's a good place to get this but I don't know where, so I'm reaching into the collective intelligence here to see what comes up.
I took off the throttle dampener a few weeks ago and had some trouble with my 89 Toyota 4X4 xtcab dying at at stoplights sometimes.
So I put it back on, and now when I take my foot off of the gas it revs the motor up to 2k. I think I need to adjust it because I tightened up the throttle about the same time I took off the dampener. Which would make the cable tighter and therefore not set at the right place when I take my foot off of the gas.
It's my understanding that I should use the slot-headed metal screw and the timing to get a good idle. Should I do that at warm or cold engine temp?
Is there a procedure for setting everything up to get the proper idle?
What does that plastic slot-headed screw do?
Any help would be appreciated!!
Old Dec 16, 2006 | 08:03 AM
langzaiguy's Avatar
Adjust it while the engine is hot. Cross TE E1 in your diagnosis box and then tweak your idle. No idea about the plastic screw. Kinda wondering that myself.
Old Dec 16, 2006 | 10:07 AM
4Crawler's Avatar
Set idle speed when hot. Plastic screw is the idle-up valve that is used to bump up the idle when A/C or P/S is used at idle.
Old Dec 16, 2006 | 11:04 AM
toyota_mdt_tech's Avatar
Better make sure your TPS is properly adjusted. It might not be which would advance timing and raise the idle speed. Then when you try to set base timing, you end up setting it way too late and have no power. You must have some slack in your throttle cable.
Old Dec 16, 2006 | 06:03 PM
943kgt's Avatar
i have this same problem with that dashpot in. it idles at 2 grand, but without it, it runs fine, so i just took it out completely and have been running it like that for like 4 months
Old Dec 17, 2006 | 03:04 PM
The dashpot is only to keep the engine from going right to an idle which rasies HC or hydrocarbons. Its just basically allows it to slowly come back to idle. The rig will run fine without it.
Old Dec 18, 2006 | 01:54 PM
nothing1's Avatar
how do you adjust the TPS and might that be a reason that my runner varies rpm at 2k rpm it just sways up and down.
Old Dec 18, 2006 | 01:58 PM
4Crawler's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Dec 18, 2006 | 08:13 PM
Joyota's Avatar
I'm misunderstanding this. Are you saying he has slack and shouldn't, or should have it and doesn't? Thanks.
Old Dec 19, 2006 | 06:53 PM
wildman326's Avatar
OK. I fiddled with the dashpot and the tension on the throttle cable and it worked better, but now when I dome off of the highway sometimes it will die?!?!
Old Dec 19, 2006 | 07:12 PM
C: none of the above. I was saying he doesnt have slack (based on his explanation) and he needs it. Some anyway, or it can always be tugging on his throttle blade.
Old Dec 19, 2006 | 08:33 PM
Joyota's Avatar
I got it now. Thank you.
Old Dec 20, 2006 | 09:12 PM
stock87's Avatar
Is this true? I was wondering because you can fail Cali smog if your idle is too high. After you un-short TE and E1, the idle comes up again.
What does the idle come up to when TE and E1 are un-shorted?
88sasturbotoy
Jan 30, 2026 01:57 PM
montanatruck
Feb 26, 2017 07:07 AM
kyletbert
Jul 17, 2015 11:39 AM
crashburnoveride
Jul 10, 2015 06:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
