rough idle at start
Old Dec 6, 2006 | 07:49 PM
curly_c's Avatar
rough idle at start
i got a 1990 3.0 runner and when i start it in the morning it really chugs, thats the best way i can think to describe it. when i start my truck the RPMs jump to 1500 or so like they usually do when i first start it, but when i rev the engine it stutters and chugs till it hit 3000RPMs then it revs good till i let off. but from 1500-3000 its really ruff, while its doing this its puffing alot of smoke and right when it chugs black smoke comes out. it only does it on a cold start, like after its been sitting over night.
i've got new cap, rotor, plugs, cleaned the TB, ran sea foam threw the engine and gas tank, and fuel injector cleaner.
it seems to lessen up a bit with higher octain fuel but when i just put in 89 octain from chevron it didnt seem to change it any. im not sure where to start, i was thinking that a sensor such as the o2 sensor might be not working and sending too much gas cuz it seems a lil rich but i checked the codes and got no code so im not sure where to start
would maybe the timing effect something like this, i think that might be my next step to check the timing
any help would be great
thans!
Old Dec 6, 2006 | 09:09 PM
pruney81's Avatar
Black smoke is oil burning, Is there alot of white smoke? Mine was doing similar symptoms on initial startup and it turned out to be a blown headgasket. I don't know it that's your problem or not tho...
Old Dec 7, 2006 | 05:34 AM
4runnerx3's Avatar
Black smoke is flooding.
Old Dec 7, 2006 | 09:31 PM
curly_c's Avatar
thats what it might seem but what would cause it to flood? im pretty lost at this point. my gas mileage seems to have taken a hit. i never got good milage to begin with but now its worse. i get 12mpg at best! now its 11! might not have to do with this directly cuz its been sputtering in the mornings for a while but i don't know whats going on.
Old Dec 8, 2006 | 03:43 AM
4runnerx3's Avatar
First thing I would check is the water temp sensor for the ECU, then the air flow meter.
Old Dec 8, 2006 | 04:02 AM
4runnermax's Avatar
Are you losing oil???? cause that would rule out a lot one way or the other
Old Dec 8, 2006 | 04:16 AM
rdharper's Avatar
The black smoke should be unburnt fuel. You risk damaging your catalytic converter with the current condition as well as failing smogII, in case you needed any encouragement to get it fixed asap. Probably you know that.
As to what might be wrong, it probable is the ECU getting wrong info from a sensor like the temp sensor or the AFM as 4unnerrx3 suggests.
Old Dec 9, 2006 | 02:02 PM
curly_c's Avatar
if either sensor was out would i get a code? cuz i checked the codes and didnt get any? how would i check to see if those are working properly.
Old Dec 10, 2006 | 09:50 AM
rdharper's Avatar
I would do a search on the various sensors, or get an FSM. It is possible to have a sensor not working correctly and not get a code.
I've not personally had to check either of the sensors in question, but I tried a search for the temp sensor.... a ton of good info came up.
Old Dec 10, 2006 | 10:32 AM
rdlsz24's Avatar
Could be an injector stuck open. Below 3k rpm's the injector stuck open is giving you too much fuel but when you get above 3k it evens out since it uses up the excess fuel from the open injector. At least that's what the guy at AutoZone explained to me. Makes sense I guess.
Rob
Charecter1
Nov 6, 2023 10:08 AM
smiley52
Jul 11, 2015 05:16 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
