Vacuum Lines are amazing
Old Dec 15, 2006 | 04:43 PM
LittleSilver113's Avatar
I recently took apart my 92 22re to replace the headgasket. Stupid me thought that the vacuum diagrams were fairly accurate. So it is all assembled now, tps adjusted, afm good, and I have a surging idle. My guess would be vacuum leak? Anyone with any input, maybe some pictures of the correct vacuum hook ups and such? Just trying to get this sorted out till summer. Thanks.
Old Dec 15, 2006 | 04:46 PM
Elton's Avatar
welcome to yotatech... sounds like a vacuum leak does it do it when you step on the brakes?
Old Dec 15, 2006 | 04:48 PM
Yeah its gets worse when you step on the brakes. Booster maybe?
Old Dec 15, 2006 | 04:53 PM
YOTAKIMMER's Avatar
I can't believe it is the booster, because there is 3 of us with this same issue now that have just recently installed engines.....we need some help guys!
Old Dec 15, 2006 | 04:56 PM
Yeah Im a little lost guys I sat there with a can of wd40 for a couple hours checking vacuum lines and only found one bad one, fixed it and not a damn bit of help lol. One other thing my truck still has white smoke out the exhaust. Burning water I suspect what are other possible culprits? I hear the timing cover is a common issue but does it let water directly into the cylinder?
Old Dec 15, 2006 | 04:58 PM
Elton's Avatar
well if the idle is set higher than 900rpms it will do it
Old Dec 15, 2006 | 05:05 PM
I have it set at 750 or 800 so that shouldnt be an issue?
Old Dec 15, 2006 | 05:29 PM
4Crawler's Avatar
Surging idle fixes:
- http://www.4crawler.com/4x4/TLCA_Tru...ech.04.09.html
Also check for low coolant level and/or air pockets in the cooling system. Causes ECU temp sensor to alternately see hot/cold/etc. and that causes idle to surge.
Vacuum line pix ('85/22RE):
- http://www.4crawler.com/4x4/CheapTri...Pix/index.html
Old Dec 17, 2006 | 04:57 PM
YOTAKIMMER's Avatar
Well, mine ended up being the idle. I turned the screw until it was closed and it still ran fine, so I just opened it a quarter turn. Idles nice and low and no more surging when coming off the throttle. Thanks for the info to fix this guys!!
raptor510
Aug 19, 2015 02:15 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
