Weird cooling issue w/ 22re
Old Sep 25, 2006 | 12:21 AM
boostaddctn's Avatar
Hi guys, new to the forums here, just recently bought a 91 Toyota Pickup 22RE 2WD A/T to use for our mt. biking trips. My dad borrowed the truck today and he told me that whenever he took the truck up to 70 - 80mph, the temperature needle would start to climb. I am assuming that the radiator is clogged (but can a bad rad cap do this also??). I also noticed that it takes a really long time for the truck to achieve normal temperature (usually about 15minutes??) is this normal also?? what can you guys recommend me to check?? thanks, aight peace
- Bert
ps- I did a search and didn't seem to find anyone with a similar problem as me.
Old Sep 25, 2006 | 04:11 AM
mt_goat's Avatar
Does it over-heat when the heater is on? Check this out: http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Old Sep 25, 2006 | 06:01 AM
MMA_Alex's Avatar
if you just bought it its usually a good idea to swap fluids. I would drain and flush the rad, replace the t-stat, and replace the cap.
Old Sep 25, 2006 | 06:39 AM
Elton's Avatar
Welcome to YotaTech ... try replacing the t-stat and see if that helps any
Old Sep 25, 2006 | 08:27 AM
Flash319's Avatar
Sounds like your t-stat is no good as it should only take a few min to warm up. Also your rad is probebly on its way out.
Old Sep 25, 2006 | 09:04 AM
Glenn's Avatar
Also check out the fan clutch. I have had the same symptoms you describe, and it turned out to be the fan clutch was not working right.
Old Sep 25, 2006 | 09:06 AM
04 Rocko Taco's Avatar
I was going to say sounds like a t-stat, fan clutch could be a good idea too. But yeah when having these issues, alwaysa good idea to go ahead and do a rad flush.
Old Sep 25, 2006 | 09:12 AM
MMA_Alex's Avatar
the fan shouldn't make a difference at 80mph as it is only used to pull air across the rad when the engine is idling, or going very slow
Old Sep 25, 2006 | 12:01 PM
Yeah thats why I didn't mention the fan clutch, cause usually after 40mph (I believe) the fan isn't needed anymore... I am going try and find time to do the thermostat and a coolant flush this weekend, any other input would help also, thanks aight peace
83yotastockR
11
Nov 10, 2015 06:54 AM
Davebarbier
Nov 3, 2015 03:28 PM
Ditch Doc
Oct 27, 2015 03:20 PM
Shagool22
Sep 28, 2015 07:53 PM
