cleaning intake mainfold
Old Sep 30, 2006 | 04:26 PM
xentrino's Avatar
I am preparing a remanned 3VZE to drop in my 94 4runner. As I was about to attach the intake maifold, I noticed there was a lot of carbon (?) build up in the ports. Should I try to clean this or will it affect anything. If cleaning is recommended, what is the best way to do it, considering that my "parts cleaner" is a hose in my back yard?
Old Sep 30, 2006 | 04:35 PM
callmej75's Avatar
I cleaned mine with a toothbrush and throttle body cleaner...or brakekleen
Old Sep 30, 2006 | 06:59 PM
dcg9381's Avatar
Carb cleaner works well.. Mine was really crapped up due to a blown turbo.. I needed to have it vatted.
Old Sep 30, 2006 | 07:04 PM
ChickenLover's Avatar
I spray carb cleaner down each runner, then stuff part of an old shirt down the runners (one at a time), then get the end caught up in a drill. Spin it till she's clean.
Old Sep 30, 2006 | 07:19 PM
GSGALLANT's Avatar
I soaked mine in mineral spirits for several hours (I don't know how much that actually helped, because the buildup was still pretty hard and crusty) I then used my dremel tool with a stainless steel brush on it (it works great, but don't use it excessively on any sealing surface.) I have a flexible extension for my dremel, so I can get in almost all the way. If you don't have that, you'll only be able to get at the first 3 or 4 inches.
For the gasket surfaces, I find that gentle scrubbing with throttle body cleaner and a brass brush or some fine steel wool works well without damaging the surface.
Old Oct 1, 2006 | 09:15 AM
xentrino's Avatar
Thanks to all for the advice. Looks like I have some cleaning to do!
Old Oct 1, 2006 | 12:36 PM
95RunnerSR5's Avatar
use a wire brush and carb cleaner...also, soak an old tshirt or rag in the cleaner and shove it into one of the six openings, stick a drillbit in the middle of the rag and walla clean!
Blamalam
Mar 12, 2022 07:34 AM
Doug4320
Mar 24, 2018 10:11 PM
ethanethan
Engine Swaps
Aug 11, 2015 09:09 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
87blyota
Jul 10, 2015 04:31 AM
