Hood Insulation questions!
Old Oct 2, 2006 | 10:27 AM
Bumpin' Yota's Avatar
Well my hood insulation is damn near gone....so I can get a new one from the dealer at what, 300+? I can leave it off and watch my hood steam like a cracked open radiator in the rain, or I can use "quick fix" from home depot to cover the underside. Quick fix is a thinner version of dynamat extreme, therefore its asphault based with an aluminum lining. The one trip up is that each strip of it is only 6" wide...lol
Has anyone run this stuff on the hood underside? And what would yall do? Just leave it be and get people to stare when im sitting at a light in the rain?
Old Oct 2, 2006 | 10:30 AM
mt_goat's Avatar
I took mine off, the Tacos don't even come with any.
Old Oct 2, 2006 | 10:32 AM
mastacox's Avatar
I took mine out after it started falling off, haven't replaced it... oh and BTW this is post #1000!!!!! (Post whore, I know)
Old Oct 2, 2006 | 10:34 AM
ebelen1's Avatar
I had a similar question when I swapped my OEM hood for the OEM scooped hood. The scooped hood didn't come w/ a liner and I asked the body shop if this would cause discoloration. He said no so I never bothered.
If you have more info, that would be helpful.
Old Oct 2, 2006 | 12:59 PM
aviator's Avatar
I would'nt worry about it that hood liner is just a sound deading thing... but if you are concerned there was a post here a long time ago about using that dynamat like product but it was in much wider sheets then 6" this stuff was in rolls about 24" wide but was black sticky I think it is sold as a roof / wall sealant strip. I know you can buy foil backed sheets of fibreglass insulation from HVAC trade suppliers. I think it is sold as fridge insulation... The stuff comes in several different thicknesses, some more rigid then others... a bit of that and some 3M spray adhesive and you'd be laughing...
Old Oct 2, 2006 | 04:29 PM
trythis's Avatar
I would like to get one for my 89, it didnt come with a liner. They are designed to extinguish fires, and I think an asphault substitute would just fuel the fire. So I havent used that or foam rubber with sticky on one side.
watching in case someone knows where to get the safe aftermarket version.
Old Oct 2, 2006 | 04:45 PM
Doc279's Avatar
I pulled the falling insulation off my 2nd generation hood 5 years ago.
It's never cracked the paint nor have I ever seen steam in the rain.
I'd guess that it's not mandatory. As far as the asphalt type - I think that
you would have a melted gooey mess and that would SUCK !!!
Use the money elsewhere !
Old Oct 2, 2006 | 04:51 PM
ovrrdrive's Avatar
My 95 didn't come with any insulation and now the hood is faded... I wish I had the insight to put insulation on it when it was new.
Old Oct 2, 2006 | 04:55 PM
Tofer's Avatar
Sponsor
i havent had mine on there for a while now too..
Old Oct 2, 2006 | 05:43 PM
Ric's Avatar
Ric
Banned - User requested
mine has it, not sure if its factory..
very nice to know,, as mine is looking very bad, and i was thinking about replcing it, but i wont worry about it now
Old Oct 2, 2006 | 06:02 PM
ChickenLover's Avatar
My OEM insulation fell off during my HG repair. I drove around without it for about a week. There was a ton of steam coming off the hood in the rain and snow.. Enough to cause concern. I got a cheap ass heat insulation pad from pep boys. I cut it to fit, and it works like a charm. I don't think it was more than 20 bucks. I would get something on there if I were you. Why chance it? You don't want your hood to end up lookin' like ˟˟˟˟˟.
Old Oct 2, 2006 | 06:19 PM
CJM's Avatar
CJM
Had one on my camry from the factory, didnt do a blessed thing AFAIK. Dont have one on the T100 and the paint is 10 years old, no discoloration, flaking or nothing.
Old Oct 2, 2006 | 06:32 PM
MonsterMaxx's Avatar
Take the hood off and take it to a spray on bedliner place.
Old Oct 2, 2006 | 07:30 PM
aviator's Avatar
Or just grab your self a rattle can of bed liner if thats what you want to do...
I agree with the other posts that asphalt stuff would just make an unholy mess of everything.
Personally other than some sort of OEM replacement part I can't improve on foil faced fibreglass...
Old Oct 2, 2006 | 07:43 PM
4x4Lamm's Avatar
Dynamat makes a good one for around $100.
I run w/o mine and will be installing Race Ace vents in the hood soon.
Lamm
Old Oct 2, 2006 | 08:15 PM
Scofco's Avatar
Mine is also gone.
Old Oct 2, 2006 | 09:24 PM
SoiledGreen98's Avatar
I don't have one. Do you think it would help with extra heat from the Arizona sun? My ride's green and the hood gets pretty hot in the summer.
Old Oct 2, 2006 | 09:40 PM
My hood is black and I live in florida...ugg...but then again the hood NEEDS a new paintjob something fierce...
Old Oct 2, 2006 | 11:19 PM
CyMoN's Avatar
i had tought of using this http://www.blueridgecompany.com/radiant/hydronic/189
Old Oct 3, 2006 | 01:51 PM
Keggo's Avatar
I could have sworn those were there to blanket (and extinguish) any engine fires that may arise. Just like one of the other guys said.
