Quick question before i drop the trans.
Old Sep 29, 2006 | 03:24 PM
runner126's Avatar
im just about to drop the transmission on my 4runner and i just wanted to know if anyone knows where the center point or balance measurment is located. I want to place the trans jack in the right place to avoid any unbalances. lookin for a point (example: 3 inches from the front of the trans on level ground).
thanks, ryan
Old Sep 29, 2006 | 03:44 PM
reggie 00's Avatar
I have always centered it and used the chains to strap it to the jack.
That is when i just don't pull it out with my knees at the bell housing and arms at the tail.
The transfer case if still attached always seems to make it awkward no mater what.
I have in the past just pulled it separate, but you don't have to.
i would get it under a good solid spot and safety chain it to the jack, and just slowly guide it down and out.
Old Sep 29, 2006 | 03:49 PM
runner126's Avatar
sounds good, ill make sure to strap it in well, the jack came with a ratchet strap. Well i hope it works. Thanks for the info!!!
Old Sep 29, 2006 | 03:58 PM
reggie 00's Avatar
Just carefully guide it down, have a second person control the jack. You might find it will need to be moved as well as lowered when it comes down.
Above all else don't get in the way if it decides to come a tumbling down, let it hit the garage floor, chances are it will only make a big oily mess.
The easy parts getting it out, stabbing that pig back in is the real challenge, be extra careful putting it back in, you will find you have to get under it and twist, curse, threaten, push, and hit it sometimes to get it in.
where in california?
Northern or southen?
Old Sep 29, 2006 | 04:39 PM
runner126's Avatar
sounds good its just about to come out now , already got my first battle wound,.....southern (santa clarita).
Old Sep 29, 2006 | 06:34 PM
runner126's Avatar
im havin a problem gettin the top part of the trans to clear the body. it keeps bumpin into the shifter area. Any suggestions??/
Old Sep 29, 2006 | 07:38 PM
reggie 00's Avatar
which part is hitting?
the shifter itself or the shifter tower?
where on the body, and what are you trig to do, get it out from under the truck or disengaged from the motor?
Old Sep 29, 2006 | 07:48 PM
runner126's Avatar
thanks i got it. It just needed alittle shifty business to get it off. Thanks for the write back. The trans is out and i found out my through out bearing was desintigrated and the pressure plate fingers were pretty much flat. . Well im takin the shot LUK clutch out and replaceing it with a OEM toyota part. Thanks for the help and next comes the suspension
Old Sep 29, 2006 | 08:00 PM
reggie 00's Avatar
No problem.
Good call on the OEM clutch. I put in a Napa clutch in my 83 and it already needs to be tore out after only a short run.
Colington
Mar 8, 2020 09:51 AM
coffey50
Jul 28, 2015 10:55 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
icentropy
Jul 14, 2015 10:23 AM
Jnkml
Jul 6, 2015 01:20 PM
